I have a Zooz Zen25 which has been problematic since the day I got it. I have heard that this is a problematic device in general, and have tried the recommended fixes (excluding and re-including the device, updating the firmware (I updated it to 2.10), and disabling all power reports with parameter 18).
The issue used to be that this device would cause every other Z Wave device to go offline (status == dead) about once per day, only resolving when I unplugged it and plugged it back in. This was a little over a year ago, and I stopped using it for some time.
I recently decided to try using it again, since I upgraded to a more powerful host machine, and am now using the latest ZWaveJS on Home Assistant OS, but it is as problematic as ever. The device will go offline nearly every time I use it, only working again after I physically unplug and plug it back in.
This might appear to be an improvement, as before it would bring down every other Z Wave device with it. However, sometimes it does not just go offline. I’m not entirely sure what is happening, but HA becomes completely unresponsive in the web UI and via SSH. I can ping the host machine, but cannot connect to HA in any way. The only fix has been to unplug and hard reset the host machine.
Again, this happens through normal use of the device (toggling the left/right outlets), but seems to occur more often when I toggle them both quickly together. Sometimes the device simply goes offline, sometimes it causes the crash described above. It never really worked properly, and I only recently started using it again, so there is not an update that caused this to start misbehaving.
I am in contact with Zooz to get this device replaced, but before doing so would like to better understand what is happening from ZWaveJS that could cause such a severe failure. After rebooting, I don’t see anything in the logs from before that looks problematic, but I may not be looking in the right place.
System Info:
- Raspberry Pi 4
- Core 2023.11.1
- Supervisor 2023.11.3
- Operating System 10.3
- Z-Wave JS 0.4.1
