A few days ago I have updated HA (core, supervisor, OS, etc.) from 2021 March versions to the latest 2021 December versions and migrated my Z-Wave devices from the deprecated Z-Wave integration to the Z-Wave JS integration.
I have a total of 9 Z-Wave devices in my network. Ever since the updates and Z-Wave JS migration one of them stops communicating after a few hours. It is an Aeotec Home energy Meter. This one measures the electric energy consumption of half of my house, so it’s pretty disturbing that after a few hours it stops sending data. I have another such Aeotec Home Energy meter for the other half of my house, that one works fine. Also this problematic one worked just fine before the updates and migration to Z-Wave JS.
When the communication stops, the only way to fix it is to go into the Z-Wave configuration of the device and change one of its Z-Wave parameter values. This action “wakes it up” (it’s not battery powered, so it does not actually sleep). Rebooting or restarting HA does not fix it. Healing the Z-Wave network does not fix it. Healing this specific device does not fix it.
Does anybody else experience similar problems in their Z-Wave network? Any idea what I could try to fix it?
Thank you!
HA Core version: 2021.12.7
Supervisor version: 2021.12.2.
HA OS version: 7.0
Running on Raspberry Pi 4.
I’m using a Z-Wave Vision USB stick, no idea what series the controller in it is. One thing is for sure, it was working well with the old (deprecated) Z-Wave integration and before the HA updates, so it can’t just be the controller’s fault, perhaps a compatibility problem with Z-Wave JS? But then why are all other Z-Wave devices in my network working fine? Why does it affect only this one Aeotec Home Energy Meter and not the other one too? Very strange…
Here is another link to the Vision Z-Wave USB stick details.
OK it looks like a 500 Series ( Z-Wave Plus) controller so that is not your issue. It is strange they are not using the Z-Wave Plus logo though. That link I posted does not affect you.
You could try starting a discussion on the node-zwavejs GitHub repo The developers there are very helpful.
Thank you for your help!
Yeah, I guess I’ll try GitHub then.
There’s one other thing I could try… to factory reset the Aeotec Home Energy Meter which is having problems… not sure if it would solve anything, but might be worth a try…
That could be worth a try. Exclude it from the network first. I habe some cheap Chinese devices that do not seem to include properly unless factory reset first.
If the device is using any Z-Wave security, it must be freshly factory reset before inclusion The inclusion process, once started must be completed within 11 seconds, I believe. Some people find the device needs a stronger than normal signal for successful secure inclusion.
