I’ve been running Home Assistant for an awful long tine and I always seem to find answers to my issues within other user postings of their problems or generalized searches for deeper explanations. However, this one has me stumped. I integrated Z-Wave JS and it is working. It is slow, erratic, and Lovelace controls are incomplete and/or don’t work well if at all. I chalked it up to JS being new and waited for updates to make improvements. But I dont see where other users are having the same kind of issues that Im having. So I think I’ve done something terribly wrong and unless I ask for help I’ll die sitting in my rocker waiting for a solution. I should mention that I have not removed the old z-wave integration but I HAVE tried to get JS working by disabling it. Here’s the error messages. Can anyone enlighten me please?
Unexpected error ZWaveError: Timeout while waiting for an ACK from the controller
at Driver.sendMessage (/usr/src/node_modules/zwave-js/src/lib/driver/Driver.ts:2405:23)
at Driver.sendCommand (/usr/src/node_modules/zwave-js/src/lib/driver/Driver.ts:2528:28)
at Driver.trySendCommandSupervised (/usr/src/node_modules/zwave-js/src/lib/driver/Driver.ts:2617:15)
at MultilevelSwitchCCAPI.set (/usr/src/node_modules/zwave-js/src/lib/commandclass/MultilevelSwitchCC.ts:173:47)
at Proxy.MultilevelSwitchCCAPI.<computed> (/usr/src/node_modules/zwave-js/src/lib/commandclass/MultilevelSwitchCC.ts:311:33)
at ZWaveNode.setValue (/usr/src/node_modules/zwave-js/src/lib/node/Node.ts:715:14)
at Function.handle (/usr/src/node_modules/@zwave-js/server/dist/lib/node/message_handler.js:17:44)
at Object.node (/usr/src/node_modules/@zwave-js/server/dist/lib/server.js:34:91)
at Client.receiveMessage (/usr/src/node_modules/@zwave-js/server/dist/lib/server.js:86:99)
at WebSocket.<anonymous> (/usr/src/node_modules/@zwave-js/server/dist/lib/server.js:39:45) {
code: 16,
context: undefined,
transactionSource: ' at Driver.sendMessage (/usr/src/node_modules/zwave-js/src/lib/driver/Driver.ts:2405:23)\n' +
' at Driver.sendCommand (/usr/src/node_modules/zwave-js/src/lib/driver/Driver.ts:2528:28)\n' +
' at Driver.trySendCommandSupervised (/usr/src/node_modules/zwave-js/src/lib/driver/Driver.ts:2617:15)\n' +
' at MultilevelSwitchCCAPI.set (/usr/src/node_modules/zwave-js/src/lib/commandclass/MultilevelSwitchCC.ts:173:47)\n' +
' at Proxy.MultilevelSwitchCCAPI.<computed> (/usr/src/node_modules/zwave-js/src/lib/commandclass/MultilevelSwitchCC.ts:311:33)\n' +
' at ZWaveNode.setValue (/usr/src/node_modules/zwave-js/src/lib/node/Node.ts:715:14)\n' +
' at Function.handle (/usr/src/node_modules/@zwave-js/server/dist/lib/node/message_handler.js:17:44)\n' +
' at Object.node (/usr/src/node_modules/@zwave-js/server/dist/lib/server.js:34:91)\n' +
' at Client.receiveMessage (/usr/src/node_modules/@zwave-js/server/dist/lib/server.js:86:99)\n' +
' at WebSocket.<anonymous> (/usr/src/node_modules/@zwave-js/server/dist/lib/server.js:39:45)'
2021-04-28T12:16:37.682Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2021-04-28T12:16:38.791Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
2021-04-28T12:16:41.508Z CNTRLR [Node 005] did not respond after 1/3 attempts. Scheduling next try in 500 ms.
2021-04-28T12:16:43.030Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2021-04-28T12:16:44.140Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
2021-04-28T12:16:46.277Z CNTRLR [Node 005] did not respond after 2/3 attempts. Scheduling next try in 500 ms.
2021-04-28T12:16:47.797Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2021-04-28T12:16:48.907Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
code: 16,
context: undefined,
2021-04-28T12:18:13.972Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2021-04-28T12:18:15.084Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
2021-04-28T12:18:17.801Z CNTRLR [Node 005] did not respond after 1/3 attempts. Scheduling next try in 500 ms.
2021-04-28T12:18:19.321Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2021-04-28T12:18:20.434Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
2021-04-28T12:18:22.548Z CNTRLR [Node 005] did not respond after 2/3 attempts. Scheduling next try in 500 ms.
2021-04-28T12:18:24.070Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2021-04-28T12:18:25.181Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
at MultilevelSwitchCCAPI.stopLevelChange (/usr/src/node_modules/zwave-js/src/lib/commandclass/MultilevelSwitchCC.ts:258:48)
at Proxy.MultilevelSwitchCCAPI.<computed> (/usr/src/node_modules/zwave-js/src/lib/commandclass/MultilevelSwitchCC.ts:374:16)
code: 16,
context: undefined,
' at MultilevelSwitchCCAPI.stopLevelChange (/usr/src/node_modules/zwave-js/src/lib/commandclass/MultilevelSwitchCC.ts:258:48)\n' +
' at Proxy.MultilevelSwitchCCAPI.<computed> (/usr/src/node_modules/zwave-js/src/lib/commandclass/MultilevelSwitchCC.ts:374:16)\n' +
