Hello everyone,
My house has a hallway with a light switch at one end but not at the other. I have purchased and installed a FIBARO built-in switch behind the existing light switch, and have purchased a Duwi ZW BJ WS to use as a wireless Z-wave switch controlling the light from the other end of the hallway (manual: https://doc.eedomus.com/files/Duewi_ZW_WS.pdf)
The Duwi wall switch is second hand, but I can’t get it to work. I’ve tried excluding before including. When Z-wave JS is set to exclusion and I press up button three times on the device, I get an error:
The logs:
2024-02-04 19:47:53.215 WARNING (MainThread) [homeassistant.setup] Setup of bluetooth is taking over 10 seconds.
2024-02-04 19:49:45.663 INFO (MainThread) [homeassistant.components.zwave_js] Enabling zwave-js-server logging
2024-02-04 19:49:45.680 WARNING (MainThread) [homeassistant.components.zwave_js] Server logging is set to LogLevel.INFO and is currently less verbose than library logging, setting server log level to DEBUG to match
2024-02-04 19:49:45.682 DEBUG (MainThread) [zwave_js_server] Publishing message:
{'command': 'driver.update_log_config',
'config': {'level': 'debug'},
'messageId': 'cc36ac59b7b44b2abe68b335ddd66558'}
2024-02-04 19:49:45.701 DEBUG (MainThread) [zwave_js_server] Received message:
WSMessage(type=<WSMsgType.TEXT: 1>, data='{"type":"event","event":{"source":"driver","event":"log config updated","config":{"enabled":true,"level":"debug","logToFile":false,"maxFiles":7,"filename":"/config/zwave_%DATE%.log","forceConsole":true}}}', extra='')
2024-02-04 19:49:45.705 DEBUG (MainThread) [zwave_js_server] Received message:
WSMessage(type=<WSMsgType.TEXT: 1>, data='{"type":"result","success":true,"messageId":"cc36ac59b7b44b2abe68b335ddd66558","result":{}}', extra='')
2024-02-04 19:49:45.706 DEBUG (MainThread) [zwave_js_server] Publishing message:
{'command': 'start_listening_logs',
'messageId': '7f6e88687cce4624a63c838794ab89e2'}
2024-02-04 19:49:45.765 DEBUG (MainThread) [zwave_js_server] Received message:
WSMessage(type=<WSMsgType.TEXT: 1>, data='{"type":"result","success":true,"messageId":"7f6e88687cce4624a63c838794ab89e2","result":{}}', extra='')
2024-02-04 19:49:45.766 INFO (MainThread) [homeassistant.components.zwave_js] Zwave-js-server logging is enabled
2024-02-04 19:49:50.196 DEBUG (MainThread) [zwave_js_server] Publishing message:
{'command': 'controller.get_state',
'messageId': 'd0b61bdc0859403881b1d327daea510e'}
2024-02-04 19:49:50.200 DEBUG (MainThread) [zwave_js_server] Publishing message:
{'command': 'driver.is_statistics_enabled',
'messageId': '50f6e1de296649abb9879da2668b82a5'}
2024-02-04 19:49:50.206 DEBUG (MainThread) [zwave_js_server] Publishing message:
{'command': 'controller.get_provisioning_entries',
'messageId': '692b7fa56e8d45a2a098e966af37dbbe'}
2024-02-04 19:49:50.216 DEBUG (MainThread) [zwave_js_server] Received message:
WSMessage(type=<WSMsgType.TEXT: 1>, data='{"type":"result","success":true,"messageId":"d0b61bdc0859403881b1d327daea510e","result":{"state":{"type":1,"homeId":4188632982,"ownNodeId":1,"isUsingHomeIdFromOtherNetwork":false,"isSISPresent":true,"wasRealPrimary":true,"manufacturerId":134,"productType":1,"productId":90,"supportedFunctionTypes":[2,3,4,5,6,7,8,9,16,17,18,19,20,21,22,23,24,28,32,33,34,35,36,39,41,42,43,44,45,65,66,68,69,70,71,72,73,74,75,76,77,80,81,83,84,85,86,87,94,96,97,98,99,102,103,128,144,146,147,152,180,182,183,184,185,186,189,190,191,210,211,212,238,239],"sucNodeId":1,"supportsTimers":false,"statistics":{"messagesTX":10,"messagesRX":19,"messagesDroppedRX":0,"NAK":0,"CAN":0,"timeoutACK":0,"timeoutResponse":0,"timeoutCallback":0,"messagesDroppedTX":0},"inclusionState":0,"sdkVersion":"6.51.10","firmwareVersion":"1.1","isPrimary":true,"isSUC":true,"nodeType":0,"status":0,"isRebuildingRoutes":false}}}', extra='')
2024-02-04 19:49:50.224 DEBUG (MainThread) [zwave_js_server] Received message:
WSMessage(type=<WSMsgType.TEXT: 1>, data='{"type":"result","success":true,"messageId":"50f6e1de296649abb9879da2668b82a5","result":{"statisticsEnabled":false}}', extra='')
2024-02-04 19:49:50.229 DEBUG (MainThread) [zwave_js_server] Received message:
WSMessage(type=<WSMsgType.TEXT: 1>, data='{"type":"result","success":true,"messageId":"692b7fa56e8d45a2a098e966af37dbbe","result":{"entries":[]}}', extra='')
2024-02-04 19:49:55.126 DEBUG (MainThread) [zwave_js_server] Publishing message:
{'command': 'controller.begin_exclusion',
'messageId': '25b6c49e88874d28863e8dbe88960332'}
2024-02-04 19:49:55.145 INFO (MainThread) [zwave_js_server.server] 2024-02-04T18:49:55.139Z:
2024-02-04T18:49:55.139Z CNTRLR starting exclusion process...
2024-02-04 19:49:55.163 DEBUG (MainThread) [zwave_js_server.server] 2024-02-04T18:49:55.160Z:
2024-02-04T18:49:55.160Z DRIVER all queues busy
2024-02-04 19:49:55.189 DEBUG (MainThread) [zwave_js_server.server] 2024-02-04T18:49:55.180Z:
2024-02-04T18:49:55.180Z SERIAL » 0x0105004bc10676 (7 bytes)
2024-02-04 19:49:55.202 DEBUG (MainThread) [zwave_js_server.server] 2024-02-04T18:49:55.196Z:
2024-02-04T18:49:55.196Z DRIVER » [REQ] [RemoveNodeFromNetwork]
payload: 0xc106
2024-02-04 19:49:55.214 DEBUG (MainThread) [zwave_js_server.server] 2024-02-04T18:49:55.210Z:
2024-02-04T18:49:55.210Z SERIAL « [ACK] (0x06)
2024-02-04 19:49:55.222 DEBUG (MainThread) [zwave_js_server.server] 2024-02-04T18:49:55.219Z:
2024-02-04T18:49:55.219Z SERIAL « 0x0107004b06010000b4 (9 bytes)
2024-02-04 19:49:55.226 DEBUG (MainThread) [zwave_js_server] Received message:
WSMessage(type=<WSMsgType.TEXT: 1>, data='{"type":"event","event":{"source":"controller","event":"statistics updated","statistics":{"messagesTX":10,"messagesRX":20,"messagesDroppedRX":0,"NAK":0,"CAN":0,"timeoutACK":0,"timeoutResponse":0,"timeoutCallback":0,"messagesDroppedTX":0}}}', extra='')
2024-02-04 19:49:55.233 DEBUG (MainThread) [zwave_js_server.server] 2024-02-04T18:49:55.225Z:
2024-02-04T18:49:55.225Z SERIAL » [ACK] (0x06)
2024-02-04 19:49:55.239 DEBUG (MainThread) [zwave_js_server.server] 2024-02-04T18:49:55.232Z:
2024-02-04T18:49:55.232Z DRIVER « [REQ] [RemoveNodeFromNetwork]
payload: 0x06010000
2024-02-04 19:49:55.251 INFO (MainThread) [zwave_js_server.server] 2024-02-04T18:49:55.247Z:
2024-02-04T18:49:55.247Z CNTRLR The controller is now ready to remove nodes
2024-02-04 19:49:55.254 DEBUG (MainThread) [zwave_js_server] Received message:
WSMessage(type=<WSMsgType.TEXT: 1>, data='{"type":"event","event":{"source":"controller","event":"exclusion started"}}', extra='')
2024-02-04 19:49:55.256 DEBUG (MainThread) [zwave_js_server] Received message:
WSMessage(type=<WSMsgType.TEXT: 1>, data='{"type":"result","success":true,"messageId":"25b6c49e88874d28863e8dbe88960332","result":{"success":true}}', extra='')
2024-02-04 19:49:55.265 DEBUG (MainThread) [zwave_js_server.server] 2024-02-04T18:49:55.257Z:
2024-02-04T18:49:55.257Z DRIVER all queues idle
2024-02-04 19:49:55.476 DEBUG (MainThread) [zwave_js_server] Received message:
WSMessage(type=<WSMsgType.TEXT: 1>, data='{"type":"event","event":{"source":"controller","event":"statistics updated","statistics":{"messagesTX":11,"messagesRX":20,"messagesDroppedRX":0,"NAK":0,"CAN":0,"timeoutACK":0,"timeoutResponse":0,"timeoutCallback":0,"messagesDroppedTX":0}}}', extra='')
2024-02-04 19:50:04.462 DEBUG (MainThread) [zwave_js_server.server] 2024-02-04T18:50:04.456Z:
2024-02-04T18:50:04.456Z SERIAL « 0x0107004b06020000b7 (9 bytes)
2024-02-04 19:50:04.466 DEBUG (MainThread) [zwave_js_server] Received message:
WSMessage(type=<WSMsgType.TEXT: 1>, data='{"type":"event","event":{"source":"controller","event":"statistics updated","statistics":{"messagesTX":11,"messagesRX":21,"messagesDroppedRX":0,"NAK":0,"CAN":0,"timeoutACK":0,"timeoutResponse":0,"timeoutCallback":0,"messagesDroppedTX":0}}}', extra='')
2024-02-04 19:50:04.472 DEBUG (MainThread) [zwave_js_server.server] 2024-02-04T18:50:04.462Z:
2024-02-04T18:50:04.462Z SERIAL » [ACK] (0x06)
2024-02-04 19:50:04.474 DEBUG (MainThread) [zwave_js_server.server] 2024-02-04T18:50:04.468Z:
2024-02-04T18:50:04.468Z DRIVER « [REQ] [RemoveNodeFromNetwork]
payload: 0x06020000
2024-02-04 19:50:04.482 DEBUG (MainThread) [zwave_js_server.server] 2024-02-04T18:50:04.476Z:
2024-02-04T18:50:04.476Z DRIVER handling request RemoveNodeFromNetwork (75)
2024-02-04 19:50:04.487 DEBUG (MainThread) [zwave_js_server.server] 2024-02-04T18:50:04.479Z:
2024-02-04T18:50:04.479Z DRIVER 1 handler registered!
2024-02-04 19:50:04.490 DEBUG (MainThread) [zwave_js_server.server] 2024-02-04T18:50:04.482Z:
2024-02-04T18:50:04.482Z DRIVER invoking handler #0
2024-02-04 19:50:04.492 INFO (MainThread) [zwave_js_server.server] 2024-02-04T18:50:04.488Z:
2024-02-04T18:50:04.488Z CNTRLR handling remove node request (status = NodeFound)
2024-02-04 19:50:05.093 DEBUG (MainThread) [zwave_js_server.server] 2024-02-04T18:50:05.088Z:
2024-02-04T18:50:05.088Z SERIAL « 0x0107004b06071500a7 (9 bytes)
2024-02-04 19:50:05.098 DEBUG (MainThread) [zwave_js_server] Received message:
WSMessage(type=<WSMsgType.TEXT: 1>, data='{"type":"event","event":{"source":"controller","event":"statistics updated","statistics":{"messagesTX":11,"messagesRX":22,"messagesDroppedRX":0,"NAK":0,"CAN":0,"timeoutACK":0,"timeoutResponse":0,"timeoutCallback":0,"messagesDroppedTX":0}}}', extra='')
2024-02-04 19:50:05.106 DEBUG (MainThread) [zwave_js_server.server] 2024-02-04T18:50:05.097Z:
2024-02-04T18:50:05.097Z SERIAL » [ACK] (0x06)
2024-02-04 19:50:05.112 DEBUG (MainThread) [zwave_js_server.server] 2024-02-04T18:50:05.105Z:
2024-02-04T18:50:05.105Z DRIVER « [REQ] [RemoveNodeFromNetwork]
payload: 0x06071500
2024-02-04 19:50:05.119 DEBUG (MainThread) [zwave_js_server.server] 2024-02-04T18:50:05.109Z:
2024-02-04T18:50:05.109Z DRIVER handling request RemoveNodeFromNetwork (75)
2024-02-04 19:50:05.121 DEBUG (MainThread) [zwave_js_server.server] 2024-02-04T18:50:05.112Z:
2024-02-04T18:50:05.112Z DRIVER 1 handler registered!
2024-02-04 19:50:05.127 DEBUG (MainThread) [zwave_js_server.server] 2024-02-04T18:50:05.115Z:
2024-02-04T18:50:05.115Z DRIVER invoking handler #0
2024-02-04 19:50:05.130 INFO (MainThread) [zwave_js_server.server] 2024-02-04T18:50:05.118Z:
2024-02-04T18:50:05.118Z CNTRLR handling remove node request (status = Failed)
2024-02-04 19:50:05.135 ERROR (MainThread) [zwave_js_server.server] 2024-02-04T18:50:05.121Z:
2024-02-04T18:50:05.121Z CNTRLR Removing the node failed
2024-02-04 19:50:05.137 DEBUG (MainThread) [zwave_js_server] Received message:
WSMessage(type=<WSMsgType.TEXT: 1>, data='{"type":"event","event":{"source":"controller","event":"exclusion failed"}}', extra='')
2024-02-04 19:50:05.139 INFO (MainThread) [zwave_js_server.server] 2024-02-04T18:50:05.126Z:
2024-02-04T18:50:05.126Z CNTRLR stopping exclusion process...
2024-02-04 19:50:05.145 DEBUG (MainThread) [zwave_js_server.server] 2024-02-04T18:50:05.138Z:
2024-02-04T18:50:05.138Z DRIVER all queues busy
2024-02-04 19:50:05.152 DEBUG (MainThread) [zwave_js_server] Publishing message:
{'command': 'controller.stop_exclusion',
'messageId': '68b11f8072ec4cc291b77fccc11af35d'}
2024-02-04 19:50:05.162 DEBUG (MainThread) [zwave_js_server.server] 2024-02-04T18:50:05.155Z:
2024-02-04T18:50:05.155Z SERIAL » 0x0105004bc50773 (7 bytes)
2024-02-04 19:50:05.173 DEBUG (MainThread) [zwave_js_server.server] 2024-02-04T18:50:05.162Z:
2024-02-04T18:50:05.162Z DRIVER » [REQ] [RemoveNodeFromNetwork]
payload: 0xc507
2024-02-04 19:50:05.185 DEBUG (MainThread) [zwave_js_server.server] 2024-02-04T18:50:05.180Z:
2024-02-04T18:50:05.180Z SERIAL « [ACK] (0x06)
2024-02-04 19:50:05.194 INFO (MainThread) [zwave_js_server.server] 2024-02-04T18:50:05.191Z:
2024-02-04T18:50:05.191Z CNTRLR stopping exclusion process...
Any ideas what I could do to make this work?
Thanks a lot for helping me learn!
Mark
