I have this error message:
2021-11-11 05:23:47 ERROR (MainThread) [homeassistant.components.zwave_js] Discovery for value Value(value_id=‘15-50-0-value-1’) on device ‘Smart Energy Switch G2’ (Node(node_id=15)) will be skipped: Value Value(value_id=‘15-50-0-value-1’) has unknown data in the following location: metadata.cc_specific.meterType. A reinterview of node Node(node_id=15) may correct this issue, but if it doesn’t, please report this issue as it may be caused by either an upstream issue with the driver or missing support for this data in the library
To try to correct the situation I rebuilt the Zwave network with the Heal Network command. The error is always the same. What should I do?
