Z-Wave JS: Failed Setup
I hope you people can help me. I have a Z-Wave.Me USB Stick with Firmware: 5.39
Since yesterday the Z-Wave doesn’t work anymore. It states this message:
Failed setup, will retry: Failed to connect: Cannot connect to host core-zwave-js:3000 ssl:default [Connect call failed (‘172.30.33.1’, 3000)]
I looked over the Z-Wave JS addon configuration, it does use the correct USB-port, and the configuration seems correct.
Restarting en reloading the USB-stick and addon didn’t help. Also the reinstall of the plugin didn’t do anything
I also notice that the addon states in his logging:
s6-supervise zwave_js: warning: unable to spawn ./run (waiting 60 seconds): Exec format error
I’m running Home Assistant Core 2025.6.2 and Z-Wave JS Current version: 0.17.0
What information do I need to share so you can help me to let it work again?
Seems I solved my own problem. The uninstall & install procedure DID solve my problem after do it a second time…
Case closed
What exactly did you uninstall and reinstall? Just Z-Wave JS?
