During the last week I’ve suddenly have had 2x Fibaro FGWP102 (wall plug) apparently fail.
Both started with “node status: dead”, “node ready: yes”. After a reboot “node ready” changes to “no”.
When the second one failed I removed and re-added the device and voila, it’s back alive!
Offcourse, I will have to rename and/or reconfigure automations and dashboards to get it back into working conditions.
My concern is that the nodes are marked as Dead prematurely since it was possible to force-remove and reinclude the device and get it back into working condition. I have both water sensors and pumps on z-wave devices, and the wrong device failing without me noticing will cause serious problems (I know, I do plan to add a secondary failsafes when time allows).
Can I force the node marked as dead back alive in order to see if this is caused by some error?
Any thoughts on how to proceed to figure out what is happening and why?
Forgot to mention: Raspberry Pi4, SSD and Z-Stick Gen 5 in a USB-hub
