Z-Wave JS - GE/Jasco 14291 / ZW4005 Switch
This is a Blueprint for the GE/Jasco 14291 / ZW4005 Switch. It’s an older switch that only supports double tap events using the Basic set and the Single tap doesn’t generate an event in Z-Wave JS. The single tap does create a state_changed event that could be used in an automation, but is not included in this template.
This device has two buttons that I refer to as “UP” and “DOWN” for the on/off paddles making this Blueprint support two (2) actions:
  • 2x for both UP and DOWN
blueprint:
  name: GE/Jasco 14291 / ZW4005 Switch (Z-Wave JS) v0.01
  description: Create automations for the GE/Jasco Switches using the Z-Wave JS integration.
  domain: automation
  input:
    ge_jasco:
      description: 'List of available GE/Jasco 14291 / ZW4005 switches
      NOTE: This device does not have Z-Wave event for Single Tap up or down'
      selector:
        device:
          integration: zwave_js
          manufacturer: GE/Jasco
          model: 14291 / ZW4005
    tap_2x_up:
      name: Tap 2x Up
      description: Action to run when Up button is pressed 2 times.
      default: []
      selector:
    tap_2x_dn:
      name: Tap 2x Down
      description: Action to run when Down button is pressed 2 times.
      default: []
      selector:
#  source_url: https://gist.github.com/shannonfritz/79517f416cbefc6cf0f0a8fe269074ab
mode: single
max_exceeded: silent
variables:
  device_id: !input 'ge_jasco'
- platform: event
  event_type: zwave_js_value_notification
  event_data:
    command_class: 32  # Basic
condition: '{{ trigger.event.data.device_id == device_id }}'
- variables:
    value: '{{ trigger.event.data.value_raw }}'
- choose:
  - conditions: '{{ value == 255 }}'
    sequence: !input 'tap_2x_up'
  - conditions: '{{ value == 0 }}'
    sequence: !input 'tap_2x_dn'
Old reply but this automation is not working for me due to the device selector not detecting my devices. I think the requirements are too strict, but im not sure how to edit blueprints. I also cant take control of it due to an error.
Regardless wanted to share this blueprint is working for me for ZW4005 and supports more types of devices ZWave-JS - GE/Jasco/Honeywell Double Taps
The manufacturer is just GE not GE/Jasco. Just change that.
