Z Wave JS Integration failed after last core update
Last update broke my Z-Wave JS integration.
Trying to reload the integration gives:
Failed to Connect: Cannot connect to host core-zwave-js:3000 ssl:default [connect call failed (‘172.30.33.4’,3000)]
The Addon log:
2024-10-28T10:02:40.666Z DRIVER
2024-10-28T10:02:41.763Z CONFIG version 13.9.0
2024-10-28T10:02:43.107Z CNTRLR querying Serial API capabilities…
2024-10-28T10:02:44.568Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2024-10-28T10:02:45.684Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
2024-10-28T10:02:47.807Z DRIVER Failed to initialize the driver: ZWaveError: Timeout while waiting for an ACK
from the controller (ZW0200)
at Driver.sendMessage (/usr/src/node_modules/zwave-js/src/lib/driver/Drive
r.ts:5905:23)
at ZWaveController.queryCapabilities (/usr/src/node_modules/zwave-js/src/l
ib/controller/Controller.ts:1144:37)
at Driver.initializeControllerAndNodes (/usr/src/node_modules/zwave-js/src
/lib/driver/Driver.ts:1535:46)
at Immediate. (/usr/src/node_modules/zwave-js/src/lib/driver/Dr
iver.ts:1336:16)
Error in driver ZWaveError: Failed to initialize the driver: ZWaveError: Timeout while waiting for an ACK from the controller (ZW0200)
at Driver.sendMessage (/usr/src/node_modules/zwave-js/src/lib/driver/Driver.ts:5905:23)
at ZWaveController.queryCapabilities (/usr/src/node_modules/zwave-js/src/lib/controller/Controller.ts:1144:37)
at Driver.initializeControllerAndNodes (/usr/src/node_modules/zwave-js/src/lib/driver/Driver.ts:1535:46)
at Immediate. (/usr/src/node_modules/zwave-js/src/lib/driver/Driver.ts:1336:16) (ZW0100)
at Immediate. (/usr/src/node_modules/zwave-js/src/lib/driver/Driver.ts:1356:6) {
code: 100,
context: undefined,
transactionSource: undefined
Shutting down
[10:02:47] WARNING: Halt add-on
s6-rc: info: service legacy-services: stopping
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/config.sh
[11:03:50] INFO: No ‘network_key’ detected, setting it to ‘s0_legacy_key’ for backwards compatibility
[11:03:52] INFO: Flushing config to disk due to creation of new key(s)…
[11:03:55] INFO: Soft-reset set to automatic
[11:03:55] INFO: Virtual Machine not detected, enabling soft-reset
cont-init: info: /etc/cont-init.d/config.sh exited 0
cont-init: info: running /etc/cont-init.d/structure.sh
cont-init: info: /etc/cont-init.d/structure.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun zwave_js (no readiness notification)
s6-rc: info: service legacy-services successfully started
[11:03:58] INFO: Successfully send discovery information to Home Assistant.
2024-10-28T10:04:01.187Z DRIVER ███████╗ ██╗ ██╗ █████╗ ██╗ ██╗ ███████╗ ██╗ ███████╗
2024-10-28T10:04:01.194Z DRIVER version 13.9.0
2024-10-28T10:04:01.195Z DRIVER
2024-10-28T10:04:02.280Z CONFIG version 13.9.0
2024-10-28T10:04:03.640Z CNTRLR querying Serial API capabilities…
2024-10-28T10:04:05.091Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2024-10-28T10:04:06.207Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
2024-10-28T10:04:08.332Z DRIVER Failed to initialize the driver: ZWaveError: Timeout while waiting for an ACK
r.ts:5905:23)
iver.ts:1336:16)
code: 100,
context: undefined,
Shutting down
[10:04:08] WARNING: Halt add-on
Any help is appreciated as I am clueless in this… :slight_smile:
/Christian
