Z-Wave JS integration: Option to include name or node number in device entity names
I think it’s confusing that the integration only uses the Product string from Z-Wave.JS (which I can’t edit) to define the device entities. I have three Telldus wallplugs of the same model, and I end up with these entities:
As I name my Z-Wave devices zwave_1, zwave_2 etc., it would be great if there was an option in the integration to use Z-Wave device names or node numbers in the entity names.
Hi Ohj,
you can easily rename your device, this action will then push the customized name as initial part of the entity name.
to do that, simply go into Configuration - then open the Device Screen directly or via the integration (Zwave JS) button to get a filtered view.
At this point, just select the device you want to rename and click on the gear located on the top right of the screen:
