Z-wave JS not starting
I have home assistant running for a few years now and i mainly use Z-wave for my wall switches. Everything worked perfectly for the past few years.
Yesterday is migrated home assistant from my SD card to a brand new SSD. I restored a backup after the installation of home assistant on the SSD. Everything works after the migration except the Z-wave JS addon. It simply won’t start. It keeps showing the “Start” button. The Z-wave intergration just show “try again: none”
I tried setting the log level to “silly” or “debug” of the Z-wave JS addon. But it changes nothing in the logs. After rebooting home assistant the debug level is back to “info”. In my opinion the weird part is that the logs do show activity on my Z-wave network although the addon isn’t started.
The USB Z-wave stick i use is detected by home assistant through the hardeware list, though it’s says the vendor ID is 0658 which points in the direction of an Aeotec Z-Stick Gen5, but i have a Z-wave.me stick. I’m not sure if this has anything to do with the issue.
Ocassionally the Z-wave JS addon logs show me an error: Client disconnected, Code 1000
What i tried so for:
  • Reboot HA several times
  • Reinstall the Z-wave JS addon, but this makes no difference, it won’t start
  • Tried to edit the configuration to work with the device: ttyAMA0
  • Tried to edit the configuration to work with the device: ttyACM0
  • Install Z-wave JS UI instead, but it’s wont start either. But i’m not sure if it’s a stand-alone addon for Z-wave so it was a longshot from my side.
  • Cursed and ranted alot, but the Z-wave JS addon didn’t budge
I’m not sure where to go from here. I hope you guys can point me in the right direction where to look. Is there any other logging i missed out on? Is there any clue i missed? What steps can i take to fix the issue? Some help would be appreciated :slight_smile:
I had exactly the same problem, unfortunately the only way I could fix it was to pull the physical power from the Pi wait a couple of minutes then power back up, then the Z-Wave allowed me to start it. Worth a try?
Thanks! You are a life saver. I really didn’t think that pulling the power supply out would make a difference on rebooting home assistant through the menu, but it did! It works now.
Ditto.
Running HA on QNAP Virtualization Station. Uninstalled and Reinstalled, re-booted, restarted the VM et. al. multiple times in multiple orders. Did NOT think about shutting down the NAS - UNTIL I found this thread.
Thanks for taking the time to write your frustrations and your success! I went through them too!
This one was biting me also. It was a restore on a lenovo pc… A Bunch of reboots, but it took the power going off to make it start working. Thanks!
