I have two Qubino Smart Plug 16A and they have been working flawlessly before Z-Wave JS had S2 support . Now that Z-Wave JS has S2 support, I removed them and then included them with S2 security. Yes, the plugs are S2 made.
The plugs were included with S2 without any hiccups, work fine for some hours and then the plugs froze over. Did nor work from HA and the (on/off) button in the plug also stopped working. I have removed and added now 2-3 times using S2 and the same happens every time. The last time tried Z-Wave JS only wanted to include the plugs insecurely:
The log (after faild S2 inclusion) does not say much:
controlled CCs:
2021-10-30T16:28:21.603Z CNTRLR [Node 020] Interview stage completed: NodeInfo
2021-10-30T16:28:21.604Z CNTRLR [Node 020] Interviewing Manufacturer Specific...
2021-10-30T16:28:21.604Z CNTRLR » [Node 020] querying manufacturer information...
2021-10-30T16:28:21.699Z CNTRLR « [Node 020] Received updated node info
2021-10-30T16:28:21.879Z CNTRLR « [Node 020] Received updated node info
2021-10-30T16:28:31.749Z CNTRLR [Node 020] Timed out while waiting for a response from the node
2021-10-30T16:28:31.756Z CNTRLR [Node 020] Interviewing Version...
2021-10-30T16:28:31.756Z CNTRLR » [Node 020] querying the CC version for Version...
2021-10-30T16:28:41.789Z CNTRLR [Node 020] Timed out while waiting for a response from the node
2021-10-30T16:28:41.789Z CNTRLR [Node 020] CC version query for Version timed out - assuming the node supports
version 1...
2021-10-30T16:28:41.790Z CNTRLR » [Node 020] querying node versions...
2021-10-30T16:28:51.887Z CNTRLR [Node 020] Timed out while waiting for a response from the node
2021-10-30T16:28:51.887Z CNTRLR » [Node 020] querying CC versions...
2021-10-30T16:28:51.888Z CNTRLR » [Node 020] querying the CC version for Basic...
2021-10-30T16:29:01.930Z CNTRLR [Node 020] Timed out while waiting for a response from the node
2021-10-30T16:29:01.930Z CNTRLR [Node 020] CC version query for Basic timed out - assuming the node supports v
ersion 1...
2021-10-30T16:29:01.930Z CNTRLR » [Node 020] querying the CC version for Binary Switch...
2021-10-30T16:29:11.966Z CNTRLR [Node 020] Timed out while waiting for a response from the node
2021-10-30T16:29:11.967Z CNTRLR [Node 020] CC version query for Binary Switch timed out - assuming the node su
pports version 1...
2021-10-30T16:29:11.967Z CNTRLR [Node 020] skipping query for All Switch (0x27) because max implemented vers
ion is 0
2021-10-30T16:29:11.967Z CNTRLR » [Node 020] querying the CC version for Z-Wave Plus Info...
2021-10-30T16:29:22.057Z CNTRLR [Node 020] Timed out while waiting for a response from the node
2021-10-30T16:29:22.057Z CNTRLR [Node 020] CC version query for Z-Wave Plus Info timed out - assuming the node
supports version 1...
2021-10-30T16:29:22.057Z CNTRLR » [Node 020] querying the CC version for Association...
2021-10-30T16:29:32.091Z CNTRLR [Node 020] Timed out while waiting for a response from the node
2021-10-30T16:29:32.091Z CNTRLR [Node 020] CC version query for Association timed out - assuming the node supp
orts version 1...
2021-10-30T16:29:32.091Z CNTRLR » [Node 020] querying the CC version for Association Group Information...
2021-10-30T16:29:42.180Z CNTRLR [Node 020] Timed out while waiting for a response from the node
2021-10-30T16:29:42.181Z CNTRLR [Node 020] CC version query for Association Group Information timed out - assu
ming the node supports version 1...
2021-10-30T16:29:42.181Z CNTRLR » [Node 020] querying the CC version for Transport Service...
2021-10-30T16:29:52.263Z CNTRLR [Node 020] Timed out while waiting for a response from the node
2021-10-30T16:29:52.263Z CNTRLR [Node 020] CC version query for Transport Service timed out - assuming the nod
2021-10-30T16:29:52.263Z CNTRLR » [Node 020] querying the CC version for Manufacturer Specific...
2021-10-30T16:30:02.378Z CNTRLR [Node 020] Timed out while waiting for a response from the node
2021-10-30T16:30:02.378Z CNTRLR [Node 020] CC version query for Manufacturer Specific timed out - assuming the
2021-10-30T16:30:02.378Z CNTRLR [Node 020] skipping query for Device Reset Locally (0x5a) because max implem
ented version is 1
2021-10-30T16:30:02.379Z CNTRLR » [Node 020] querying the CC version for Configuration...
2021-10-30T16:30:12.479Z CNTRLR [Node 020] Timed out while waiting for a response from the node
2021-10-30T16:30:12.479Z CNTRLR [Node 020] CC version query for Configuration timed out - assuming the node su
pports version 1...
2021-10-30T16:30:12.480Z CNTRLR » [Node 020] querying the CC version for Meter...
2021-10-30T16:30:22.660Z CNTRLR [Node 020] Timed out while waiting for a response from the node
2021-10-30T16:30:22.661Z CNTRLR [Node 020] CC version query for Meter timed out - assuming the node supports v
ersion 1...
2021-10-30T16:30:22.661Z CNTRLR » [Node 020] querying the CC version for Notification...
2021-10-30T16:30:32.795Z CNTRLR [Node 020] Timed out while waiting for a response from the node
2021-10-30T16:30:32.795Z CNTRLR [Node 020] CC version query for Notification timed out - assuming the node sup
ports version 1...
2021-10-30T16:30:32.796Z CNTRLR [Node 020] skipping query for Powerlevel (0x73) because max implemented vers
ion is 0
2021-10-30T16:30:32.796Z CNTRLR » [Node 020] querying the CC version for Supervision...
2021-10-30T16:30:42.866Z CNTRLR [Node 020] Timed out while waiting for a response from the node
2021-10-30T16:30:42.866Z CNTRLR [Node 020] CC version query for Supervision timed out - assuming the node supp
orts version 1...
2021-10-30T16:30:42.866Z CNTRLR » [Node 020] querying the CC version for Firmware Update Meta Data...
2021-10-30T16:30:52.904Z CNTRLR [Node 020] Timed out while waiting for a response from the node
2021-10-30T16:30:52.904Z CNTRLR [Node 020] CC version query for Firmware Update Meta Data timed out - assuming
2021-10-30T16:30:52.905Z CNTRLR [Node 020] skipping query for Security 2 (0x9f) because max implemented vers
ion is 1
2021-10-30T16:30:52.913Z CNTRLR [Node 020] Interviewing Z-Wave Plus Info...
2021-10-30T16:30:52.914Z CNTRLR » [Node 020] querying Z-Wave+ information...
2021-10-30T16:30:53.007Z CNTRLR « [Node 020] received response for Z-Wave+ information:
Z-Wave+ version: 1
role type: AlwaysOnSlave
node type: Node
installer icon: 0x0700
user icon: 0x0700
2021-10-30T16:30:53.008Z CNTRLR [Node 020] Interviewing Association...
2021-10-30T16:30:53.008Z CNTRLR » [Node 020] querying number of association groups...
2021-10-30T16:31:03.067Z CNTRLR [Node 020] Timed out while waiting for a response from the node
2021-10-30T16:31:03.068Z CNTRLR [Node 020] Querying association groups timed out, skipping interview...
2021-10-30T16:31:03.073Z CNTRLR [Node 020] Interviewing Association Group Information...
2021-10-30T16:31:03.076Z CNTRLR [Node 020] Interviewing Binary Switch...
2021-10-30T16:31:03.077Z CNTRLR » [Node 020] querying Binary Switch state...
2021-10-30T16:31:13.167Z CNTRLR [Node 020] Timed out while waiting for a response from the node
2021-10-30T16:31:13.174Z CNTRLR [Node 020] Interviewing Configuration...
2021-10-30T16:31:13.174Z CNTRLR [Node 020] ConfigurationCC: skipping interview because CC version is < 3 and t
here is no config file
2021-10-30T16:31:13.176Z CNTRLR [Node 020] Interviewing Meter...
2021-10-30T16:31:13.176Z CNTRLR » [Node 020] querying default meter value...
2021-10-30T16:31:23.208Z CNTRLR [Node 020] Timed out while waiting for a response from the node
2021-10-30T16:31:23.214Z CNTRLR [Node 020] Interviewing Notification...
2021-10-30T16:31:23.216Z CNTRLR [Node 020] Interview stage completed: CommandClasses
2021-10-30T16:31:23.217Z CNTRLR [Node 020] Interview stage completed: OverwriteConfig
2021-10-30T16:31:23.218Z CNTRLR [Node 020] Interview completed
2021-10-30T16:31:23.219Z CNTRLR [Node 020] The node is ready to be used
Starting logging event forwarder at info level
Stopping logging event forwarder
Do others experience problems with S2 inclusion or other hiccups after S2 inclusion?
/Z-Wave JS/Driver Version: 8.4.1/Server Version: 1.10.7, - Aeotec Z-stick 7, -HA Blue)
