Hello:
I have attempted to re-install Z-Wave JS post a HA failure.
I am running into a message within the Integration,
“Retrying setup: Z-Wave JS Server version is incompatible: 1.0.0 a version is required that supports at least api schema 8”
This message does not state what version it is seeing upon the attempt to connect.
[ Would be nice… ]
My current HA setup is running inside Oracle VM.
HA Core Version core-2021.9.5
HA Supervisor Version supervisor-2021.09.0
HA Host Operating System Home Assistant OS 6.2
Using an Aeotec Gen 5+ USB Stick.
It is seen in System Hardware:
Address: DEVLINKS: >- /dev/serial/by-id/usb-0658_0200-if00
Which is what I would expect.
I have uninstalled via the UI Z-Wave JS.
Then re-installed Z-Wave JS version: 0.1.8
The changelog states this is Z-Wave JS Server to 1.0.0
When I add the Z-Wave JS Integration it fails with the following message:
I clearly am doing something incorrectly. Any guidance would be appreciated.
Jim
