Hey, so I started migrating to Z-Wave JS and it’s up and running but the response times, especially when turning on for some reason, are terrible. It sometimes take 15 seconds for the light to turn on. When I turn them off and on from the old deprecated z-wave integration, the lights work great. Is it because I’m running both integrations?
Here’s a log sample from the Z-Wave JS Server add-on:
New client
New client
Client disconnected
Code 1000:
13:12:42.184 DRIVER Dropping message because it contains invalid data
13:12:42.228 DRIVER Dropping message because it contains invalid data
13:12:42.860 DRIVER no handlers registered!
13:12:53.675 DRIVER no handlers registered!
13:13:03.133 DRIVER no handlers registered!
13:13:21.671 DRIVER no handlers registered!
13:13:34.467 DRIVER Dropping message because it contains invalid data
13:13:34.479 DRIVER Dropping message because it contains invalid data
13:13:34.482 DRIVER Dropping message because it contains invalid data
13:18:02.611 CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
13:18:03.726 CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
13:18:05.851 CNTRLR [Node 007] did not respond after 1/3 attempts. Scheduling next try in 500 ms.
13:18:07.375 CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
13:18:08.487 CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
13:18:10.607 CNTRLR [Node 007] did not respond after 2/3 attempts. Scheduling next try in 500 ms.
13:18:12.134 CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
13:18:13.245 CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
Unexpected error ZWaveError: Timeout while waiting for an ACK from the controller
at Object.sendDataErrorToZWaveError (/usr/lib/node_modules/@zwave-js/server/node_modules/zwave-js/src/lib/driver/StateMachineShared.ts:69:11)
at /usr/lib/node_modules/@zwave-js/server/node_modules/zwave-js/src/lib/driver/SendThreadMachine.ts:436:4
at /usr/lib/node_modules/@zwave-js/server/node_modules/xstate/lib/utils.js:410:33
at Array.reduce (<anonymous>)
at Object.updateContext (/usr/lib/node_modules/@zwave-js/server/node_modules/xstate/lib/utils.js:400:25)
at Object.resolveActions (/usr/lib/node_modules/@zwave-js/server/node_modules/xstate/lib/actions.js:409:19)
at StateNode.resolveTransition (/usr/lib/node_modules/@zwave-js/server/node_modules/xstate/lib/StateNode.js:787:35)
at StateNode.transition (/usr/lib/node_modules/@zwave-js/server/node_modules/xstate/lib/StateNode.js:733:21)
at StateNode.resolveRaisedTransition (/usr/lib/node_modules/@zwave-js/server/node_modules/xstate/lib/StateNode.js:738:22)
at StateNode.resolveTransition (/usr/lib/node_modules/@zwave-js/server/node_modules/xstate/lib/StateNode.js:873:39) {
code: 16,
context: undefined,
transactionSource: 'Transaction: \n' +
' at Driver.sendMessage (/usr/lib/node_modules/@zwave-js/server/node_modules/zwave-js/src/lib/driver/Driver.ts:2061:23)\n' +
' at Driver.sendCommand (/usr/lib/node_modules/@zwave-js/server/node_modules/zwave-js/src/lib/driver/Driver.ts:2162:28)\n' +
' at BinarySwitchCCAPI.set (/usr/lib/node_modules/@zwave-js/server/node_modules/zwave-js/src/lib/commandclass/BinarySwitchCC.ts:111:21)\n' +
' at Proxy.BinarySwitchCCAPI.<computed> (/usr/lib/node_modules/@zwave-js/server/node_modules/zwave-js/src/lib/commandclass/BinarySwitchCC.ts:124:14)\n' +
' at ZWaveNode.setValue (/usr/lib/node_modules/@zwave-js/server/node_modules/zwave-js/src/lib/node/Node.ts:667:14)\n' +
' at Function.handle (/usr/lib/node_modules/@zwave-js/server/dist/lib/node/message_handler.js:15:44)\n' +
' at Object.node (/usr/lib/node_modules/@zwave-js/server/dist/lib/server.js:30:91)\n' +
' at Client.receiveMessage (/usr/lib/node_modules/@zwave-js/server/dist/lib/server.js:61:99)\n' +
' at WebSocket.<anonymous> (/usr/lib/node_modules/@zwave-js/server/dist/lib/server.js:35:45)\n' +
' at WebSocket.emit (events.js:315:20)'
13:18:16.746 CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
13:18:17.858 CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
13:18:19.977 CNTRLR [Node 007] did not respond after 1/3 attempts. Scheduling next try in 500 ms.
13:18:21.504 CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
13:18:22.615 CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
13:18:24.732 CNTRLR [Node 007] did not respond after 2/3 attempts. Scheduling next try in 500 ms.
13:18:26.276 CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
