Is there instructions or information on how to migrate the Z-Wave JS addon in Home Assistant to a stand alone Z-Wave JS UI setup?
my current configuration is as follow
I have a Raspberry Pi on the middle of my home with the USB Z-wave stick on it, and the Raspberry Pi is running USBIP service
my current Home Assistant instance is running on a Debian 11 VM running in supervised mode and is also running USBIP as a client, that is connected to the Raspberry Pi and passes thru the USB and the VM thinks that is a local USB
but now I would like to just run the Z-Wave JS UI docker container in the Raspberry Pi and then have Home Assistant just integrate to that container and complete remove USBIP out of the equation
The reason for this, is that I ultimately will my HA instance running un Kubernetes and USBIP is my current blocker
I’m also thinking that maybe I will have to remove all my Z-wave devices and start fresh, but I was trying to prevent that
any info would be greatly appreciated
