Wiped zwave and Addons and Integrations.
Hard Reboot of Home Assistant starting over again.
Home Assistant Community Add-on Z-Wave JS UI
Sorry missing some fundamentals - I need the ZWAVE JS UI Add on but not the add on.
Donât install the add on but install the add on - I know it is frustrating and sorry for being such a noob here.
On other Home Automation systems I have used you enable ZWAVE and off you go.
I am struggling with Integrations that are Add-Ons and Add-Ons that are applications.
I can see Zwave as an Integration AND as a ADD-ON.
While nice to spoilt for choice âŚ
So given you have kindly pointed directly to the âHome Assistant Community Add-on: Z-Wave JS UIâ I am starting from scratch and installing that.
(struggling with
And the integration you point me to is called an Add-on
âHome Assistant Community Add-on: Z-Wave JS UIâ.
Ok so
- Installed the from the link Home Assistant Community Add-on: Z-Wave JS UI
- Opened the the Z-Wave JS interface/Went to Settings/Z-Wave - selected the Zwave device
- Entered the Security keys (copied from other Home Assistant install) - Saved it
- Installed Z-Wave using +Add Integration
- UNCHECKED the box to use the add-on
- Entered ws://aod7b954-zwavejs2mqtt:3000 (as instructed) pressed Submit
![Screenshot 2024-11-28 at 11.54.22 AM|404x275]
(upload://AaJOQTHvAFB8hm6eRIUpRMF2q4J.png)
Stalled at that point.
Now what you appeared to say earlier on ion the thread was
But that contradicts you later instructions
https://community-assets.home-assistant.io/original/4X/9/6/4/9643b0d5adb42cda9980ed3b213a0a0d2544c798.png
Tried NOT Setting it and I get
So have left that web session while I try to locate a valid URL because it wonât accept ws://aod7b954-zwavejs2mqtt:3000
Leaving that session open, opened another to the Home Assistant Green
Checked the Z-Wave JS UI and all my devices are being found and is in the process of interviewing them - just lost all the names and locations.
I will hold off Restoring the Z-Wave JS UI backup for the moment until I can find the URL for the ws.
So if I understand this correctlyâŚ
You install the
- Home Assistant Add-On Z-Wave JS UI
- Select the OPEN WEB UI
- Go to the Settings
- Z-Wave - check box to enable
- Select the Zwave controller from the drop down list for Serial Port
- Either copy the Security keys from previous install OR generate new Security Keys
- No other settings required
- Go to Home Assistant Settings/ Devices & Services
- Add Z-Wave Integration
- You will be asked to use the Add-on you UNCHECK the box and it will install the add-on
- Next it will ask you to enter the url of the WS Server enter ws://aod7b954-zwavejs2mqtt:3000 and it should then work
So just step 11 I am stuck on right now
