Attached image file without the stop button and dagnostic. Thanks for your help.
{"home_assistant":{"installation_type":"Home Assistant OS","version":"2023.11.2","dev":false,"hassio":true,"virtualenv":false,"python_version":"3.11.6","docker":true,"arch":"x86_64","timezone":"Europe/Madrid","os_name":"Linux","os_version":"6.1.59","supervisor":"2023.11.0","host_os":"Home Assistant OS 11.1","docker_version":"24.0.6","chassis":"vm","run_as_root":true},"custom_components":{"hacs":{"version":"1.33.0","requirements":["aiogithubapi>=22.10.1"]},"huawei_solar":{"version":"1.2.8","requirements":["huawei-solar==2.2.9"]},"nodered":{"version":"3.1.1","requirements":[]},"pvpc_hourly_pricing":{"version":"1.1.1","requirements":["aiopvpc>=4.2.1"]},"solcast_solar":{"version":"4.0.12","requirements":["aiohttp>=3.6.2","datetime>=4.3","isodate>=0.6.1"]},"illuminance":{"version":"4.1.0","requirements":[]},"sonoff":{"version":"3.5.3","requirements":["pycryptodome>=3.6.6"]},"adaptive_lighting":{"version":"1.19.0","requirements":["ulid-transform"]},"balance_neto":{"version":"0.1.0","requirements":[]}},"integration_manifest":{"domain":"zwave_js","name":"Z-Wave","codeowners":["@home-assistant/z-wave"],"config_flow":true,"dependencies":["http","repairs","usb","websocket_api"],"documentation":"https://www.home-assistant.io/integrations/zwave_js","integration_type":"hub","iot_class":"local_push","loggers":["zwave_js_server"],"quality_scale":"platinum","requirements":["pyserial==3.5","zwave-js-server-python==0.53.1"],"usb":[{"vid":"0658","pid":"0200","known_devices":["Aeotec Z-Stick Gen5+","Z-WaveMe UZB"]},{"vid":"10C4","pid":"8A2A","description":"*z-wave*","known_devices":["Nortek HUSBZB-1"]}],"zeroconf":["_zwave-js-server._tcp.local."],"is_built_in":true},"data":{"versionInfo":{"driverVersion":"12.3.0","serverVersion":"1.33.0","minSchemaVersion":0,"maxSchemaVersion":33},"entities":[{"domain":"sensor","entity_id":"sensor.micro_motor_controller_power","original_name":"Power","original_device_class":"power","disabled":false,"disabled_by":null,"hidden_by":null,"original_icon":null,"entity_category":null,"supported_features":0,"unit_of_measurement":"W","value_id":"26-49-0-Power","primary_value":{"command_class":49,"command_class_name":"Multilevel Sensor","endpoint":0,"property":"Power","property_name":"Power","property_key":null,"property_key_name":null}},{"domain":"sensor","entity_id":"sensor.micro_motor_controller_electric_consumption_kwh","original_name":"Electric Consumption [kWh]","original_device_class":"energy","disabled":false,"disabled_by":null,"hidden_by":null,"original_icon":null,"entity_category":null,"supported_features":0,"unit_of_measurement":"kWh","value_id":"26-50-0-value-65537","primary_value":{"command_class":50,"command_class_name":"Meter","endpoint":0,"property":"value","property_name":"value","property_key":65537,"property_key_name":"Electric_kWh_Consumed"}},{"domain":"sensor","entity_id":"sensor.micro_motor_controller_electric_consumption_w","original_name":"Electric Consumption [W]","original_device_class":"power","disabled":false,"disabled_by":null,"hidden_by":null,"original_icon":null,"entity_category":null,"supported_features":0,"unit_of_measurement":"W","value_id":"26-50-0-value-66049","primary_value":{"command_class":50,"command_class_name":"Meter","endpoint":0,"property":"value","property_name":"value","property_key":66049,"property_key_name":"Electric_W_Consumed"}},{"domain":"switch","entity_id":"switch.micro_motor_controller","original_name":"","original_device_class":null,"disabled":false,"disabled_by":null,"hidden_by":null,"original_icon":null,"entity_category":null,"supported_features":0,"unit_of_measurement":null,"value_id":"26-37-0-currentValue","primary_value":{"command_class":37,"command_class_name":"Binary Switch","endpoint":0,"property":"currentValue","property_name":"currentValue","property_key":null,"property_key_name":null}},{"domain":"select","entity_id":"select.micro_motor_controller_send_notifications_to_associated_devices_group_1","original_name":"Send Notifications to Associated Devices (Group 1)","original_device_class":null,"disabled":true,"disabled_by":"integration","hidden_by":null,"original_icon":null,"entity_category":"config","supported_features":0,"unit_of_measurement":null,"value_id":"26-112-0-80","primary_value":{"command_class":112,"command_class_name":"Configuration","endpoint":0,"property":80,"property_name":"Send Notifications to Associated Devices (Group 1)","property_key":null,"property_key_name":null}},{"domain":"select","entity_id":"select.micro_motor_controller_external_switch_type","original_name":"External Switch Type","original_device_class":null,"disabled":true,"disabled_by":"integration","hidden_by":null,"original_icon":null,"entity_category":"config","supported_features":0,"unit_of_measurement":null,"value_id":"26-112-0-120","primary_value":{"command_class":112,"command_class_name":"Configuration","endpoint":0,"property":120,"property_name":"External Switch Type","property_key":null,"property_key_name":null}},{"domain":"select","entity_id":"select.micro_motor_controller_motor_start_delay_time","original_name":"Motor Start Delay Time","original_device_class":null,"disabled":true,"disabled_by":"integration","hidden_by":null,"original_icon":null,"entity_category":"config","supported_features":0,"unit_of_measurement":null,"value_id":"26-112-0-4","primary_value":{"command_class":112,"command_class_name":"Configuration","endpoint":0,"property":4,"property_name":"Motor Start Delay Time","property_key":null,"property_key_name":null}},{"domain":"select","entity_id":"select.micro_motor_controller_opening_time","original_name":"Opening Time","original_device_class":null,"disabled":true,"disabled_by":"integration","hidden_by":null,"original_icon":null,"entity_category":"config","supported_features":0,"unit_of_measurement":null,"value_id":"26-112-0-5","primary_value":{"command_class":112,"command_class_name":"Configuration","endpoint":0,"property":5,"property_name":"Opening Time","property_key":null,"property_key_name":null}},{"domain":"select","entity_id":"select.micro_motor_controller_closing_time","original_name":"Closing Time","original_device_class":null,"disabled":true,"disabled_by":"integration","hidden_by":null,"original_icon":null,"entity_category":"config","supported_features":0,"unit_of_measurement":null,"value_id":"26-112-0-6","primary_value":{"command_class":112,"command_class_name":"Configuration","endpoint":0,"property":6,"property_name":"Closing Time","property_key":null,"property_key_name":null}},{"domain":"select","entity_id":"select.micro_motor_controller_state_after_power_failure","original_name":"State After Power Failure","original_device_class":null,"disabled":true,"disabled_by":"integration","hidden_by":null,"original_icon":null,"entity_category":"config","supported_features":0,"unit_of_measurement":null,"value_id":"26-112-0-7","primary_value":{"command_class":112,"command_class_name":"Configuration","endpoint":0,"property":7,"property_name":"State After Power Failure","property_key":null,"property_key_name":null}},{"domain":"select","entity_id":"select.micro_motor_controller_count_of_external_buttons_switches","original_name":"Count of External Buttons/Switches","original_device_class":null,"disabled":true,"disabled_by":"integration","hidden_by":null,"original_icon":null,"entity_category":"config","supported_features":0,"unit_of_measurement":null,"value_id":"26-112-0-8","primary_value":{"command_class":112,"command_class_name":"Configuration","endpoint":0,"property":8,"property_name":"Count of External Buttons/Switches","property_key":null,"property_key_name":null}},{"domain":"number","entity_id":"number.micro_motor_controller_device_tag","original_name":"Device Tag","original_device_class":null,"disabled":true,"disabled_by":"integration","hidden_by":null,"original_icon":null,"entity_category":"config","supported_features":0,"unit_of_measurement":null,"value_id":"26-112-0-254","primary_value":{"command_class":112,"command_class_name":"Configuration","endpoint":0,"property":254,"property_name":"Device Tag","property_key":null,"property_key_name":null}},{"domain":"cover","entity_id":"cover.micro_motor_controller","original_name":"","original_device_class":"window","disabled":false,"disabled_by":null,"hidden_by":null,"original_icon":null,"entity_category":null,"supported_features":7,"unit_of_measurement":null,"value_id":"26-38-0-currentValue","primary_value":{"command_class":38,"command_class_name":"Multilevel Switch","endpoint":0,"property":"currentValue","property_name":"currentValue","property_key":null,"property_key_name":null}}],"state":{"nodeId":26,"index":0,"status":4,"ready":true,"isListening":true,"isRouting":true,"isSecure":false,"manufacturerId":134,"productId":14,"productType":3,"firmwareVersion":"1.23","name":"Persiana","location":"**REDACTED**","deviceConfig":{"filename":"/data/db/devices/0x0086/dsc14.json","isEmbedded":true,"manufacturer":"AEON Labs","manufacturerId":134,"label":"DSC14","description":"Micro Motor Controller","devices":[{"productType":3,"productId":14}],"firmwareVersion":{"min":"0.0","max":"255.255"},"preferred":false,"associations":{},"paramInformation":{"_map":{}}},"label":"DSC14","interviewAttempts":0,"isFrequentListening":false,"maxDataRate":40000,"supportedDataRates":[40000],"protocolVersion":2,"supportsBeaming":true,"supportsSecurity":false,"nodeType":1,"deviceClass":{"basic":{"key":4,"label":"Routing Slave"},"generic":{"key":17,"label":"Multilevel Switch"},"specific":{"key":5,"label":"Motor Control Class A"},"mandatorySupportedCCs":[32,38,37,114,134],"mandatoryControlledCCs":[]},"interviewStage":"Complete","deviceDatabaseUrl":"https://devices.zwave-js.io/?jumpTo=0x0086:0x0003:0x000e:1.23","statistics":{"commandsTX":25,"commandsRX":6,"commandsDroppedRX":0,"commandsDroppedTX":0,"timeoutResponse":0,"rtt":1109.2,"lastSeen":"2023-11-13T19:21:57.793Z"},"highestSecurityClass":-1,"isControllerNode":false,"keepAwake":false,"lastSeen":"2023-11-13T19:21:57.793Z","values":{"26-37-0-currentValue":{"endpoint":0,"commandClass":37,"commandClassName":"Binary Switch","property":"currentValue","propertyName":"currentValue","ccVersion":1,"metadata":{"type":"boolean","readable":true,"writeable":false,"label":"Current value","stateful":true,"secret":false},"value":null},"26-37-0-targetValue":{"endpoint":0,"commandClass":37,"commandClassName":"Binary Switch","property":"targetValue","propertyName":"targetValue","ccVersion":1,"metadata":{"type":"boolean","readable":true,"writeable":true,"label":"Target value","valueChangeOptions":["transitionDuration"],"stateful":true,"secret":false},"value":false},"26-38-0-currentValue":{"endpoint":0,"commandClass":38,"commandClassName":"Multilevel Switch","property":"currentValue","propertyName":"currentValue","ccVersion":3,"metadata":{"type":"number","readable":true,"writeable":false,"label":"Current value","min":0,"max":99,"stateful":true,"secret":false},"value":99},"26-38-0-targetValue":{"endpoint":0,"commandClass":38,"commandClassName":"Multilevel Switch","property":"targetValue","propertyName":"targetValue","ccVersion":3,"metadata":{"type":"number","readable":true,"writeable":true,"label":"Target value","valueChangeOptions":["transitionDuration"],"min":0,"max":99,"stateful":true,"secret":false},"value":99},"26-38-0-duration":{"endpoint":0,"commandClass":38,"commandClassName":"Multilevel Switch","property":"duration","propertyName":"duration","ccVersion":3,"metadata":{"type":"duration","readable":true,"writeable":false,"label":"Remaining duration","stateful":true,"secret":false}},"26-38-0-restorePrevious":{"endpoint":0,"commandClass":38,"commandClassName":"Multilevel Switch","property":"restorePrevious","propertyName":"restorePrevious","ccVersion":3,"metadata":{"type":"boolean","readable":false,"writeable":true,"label":"Restore previous value","states":{"true":"Restore"},"stateful":true,"secret":false}},"26-49-0-Power":{"endpoint":0,"commandClass":49,"commandClassName":"Multilevel Sensor","property":"Power","propertyName":"Power","ccVersion":3,"metadata":{"type":"number","readable":true,"writeable":false,"label":"Power","ccSpecific":{"sensorType":4,"scale":0},"unit":"W","stateful":true,"secret":false},"value":0.008},"26-50-0-value-65537":{"endpoint":0,"commandClass":50,"commandClassName":"Meter","property":"value","propertyKey":65537,"propertyName":"value","propertyKeyName":"Electric_kWh_Consumed","ccVersion":2,"metadata":{"type":"number","readable":true,"writeable":false,"label":"Electric Consumption [kWh]","ccSpecific":{"meterType":1,"scale":0,"rateType":1},"unit":"kWh","stateful":true,"secret":false},"value":0},"26-50-0-value-66049":{"endpoint":0,"commandClass":50,"commandClassName":"Meter","property":"value","propertyKey":66049,"propertyName":"value","propertyKeyName":"Electric_W_Consumed","ccVersion":2,"metadata":{"type":"number","readable":true,"writeable":false,"label":"Electric Consumption [W]","ccSpecific":{"meterType":1,"scale":2,"rateType":1},"unit":"W","stateful":true,"secret":false},"value":0.008},"26-50-0-reset":{"endpoint":0,"commandClass":50,"commandClassName":"Meter","property":"reset","propertyName":"reset","ccVersion":2,"metadata":{"type":"boolean","readable":false,"writeable":true,"label":"Reset accumulated values","states":{"true":"Reset"},"stateful":true,"secret":false}},"26-112-0-80":{"endpoint":0,"commandClass":112,"commandClassName":"Configuration","property":80,"propertyName":"Send Notifications to Associated Devices (Group 1)","ccVersion":1,"metadata":{"type":"number","readable":true,"writeable":true,"label":"Send Notifications to Associated Devices (Group 1)","default":0,"min":0,"max":2,"states":{"0":"Disable","1":"Hail CC","2":"Basic CC Report"},"valueSize":1,"format":1,"allowManualEntry":false,"isFromConfig":true},"value":0},"26-112-0-120":{"endpoint":0,"commandClass":112,"commandClassName":"Configuration","property":120,"propertyName":"External Switch Type","ccVersion":1,"metadata":{"type":"number","readable":true,"writeable":true,"label":"External Switch Type","default":0,"min":0,"max":1,"states":{"0":"Momentary mode","1":"Switch mode"},"valueSize":1,"format":0,"allowManualEntry":false,"isFromConfig":true},"value":0},"26-112-0-254":{"endpoint":0,"commandClass":112,"commandClassName":"Configuration","property":254,"propertyName":"Device Tag","ccVersion":1,"metadata":{"type":"number","readable":true,"writeable":true,"label":"Device Tag","default":0,"min":0,"max":65535,"valueSize":2,"format":1,"allowManualEntry":true,"isFromConfig":true},"value":0},"26-112-0-4":{"endpoint":0,"commandClass":112,"commandClassName":"Configuration","property":4,"propertyName":"Motor Start Delay Time","ccVersion":1,"metadata":{"type":"number","readable":true,"writeable":true,"label":"Motor Start Delay Time","default":0,"min":0,"max":2,"states":{"0":"Disable","1":"Hail CC","2":"Basic CC Report"},"unit":"ms","valueSize":1,"format":1,"allowManualEntry":false,"isFromConfig":true}},"26-112-0-5":{"endpoint":0,"commandClass":112,"commandClassName":"Configuration","property":5,"propertyName":"Opening Time","ccVersion":1,"metadata":{"type":"number","readable":true,"writeable":true,"label":"Opening Time","default":0,"min":0,"max":2,"states":{"0":"Disable","1":"Hail CC","2":"Basic CC Report"},"unit":"ms","valueSize":1,"format":1,"allowManualEntry":false,"isFromConfig":true}},"26-112-0-6":{"endpoint":0,"commandClass":112,"commandClassName":"Configuration","property":6,"propertyName":"Closing Time","ccVersion":1,"metadata":{"type":"number","readable":true,"writeable":true,"label":"Closing Time","default":0,"min":0,"max":2,"states":{"0":"Disable","1":"Hail CC","2":"Basic CC Report"},"unit":"ms","valueSize":1,"format":1,"allowManualEntry":false,"isFromConfig":true}},"26-112-0-7":{"endpoint":0,"commandClass":112,"commandClassName":"Configuration","property":7,"propertyName":"State After Power Failure","ccVersion":1,"metadata":{"type":"number","readable":true,"writeable":true,"label":"State After Power Failure","default":0,"min":0,"max":2,"states":{"0":"Stop","1":"Open","2":"Close"},"valueSize":1,"format":0,"allowManualEntry":false,"isFromConfig":true}},"26-112-0-8":{"endpoint":0,"commandClass":112,"commandClassName":"Configuration","property":8,"propertyName":"Count of External Buttons/Switches","ccVersion":1,"metadata":{"type":"number","readable":true,"writeable":true,"label":"Count of External Buttons/Switches","default":0,"min":0,"max":1,"states":{"0":"Three buttons","1":"One button"},"valueSize":1,"format":0,"allowManualEntry":false,"isFromConfig":true}},"26-112-0-255":{"endpoint":0,"commandClass":112,"commandClassName":"Configuration","property":255,"propertyName":"Reset to Factory Defaults","ccVersion":1,"metadata":{"type":"number","readable":false,"writeable":true,"label":"Reset to Factory Defaults","default":0,"min":0,"max":1,"states":{"0":"Normal Operation","1":"Reset to Factory Default"},"valueSize":1,"format":1,"allowManualEntry":false,"isFromConfig":true}},"26-114-0-manufacturerId":{"endpoint":0,"commandClass":114,"commandClassName":"Manufacturer Specific","property":"manufacturerId","propertyName":"manufacturerId","ccVersion":1,"metadata":{"type":"number","readable":true,"writeable":false,"label":"Manufacturer ID","min":0,"max":65535,"stateful":true,"secret":false},"value":134},"26-114-0-productType":{"endpoint":0,"commandClass":114,"commandClassName":"Manufacturer Specific","property":"productType","propertyName":"productType","ccVersion":1,"metadata":{"type":"number","readable":true,"writeable":false,"label":"Product type","min":0,"max":65535,"stateful":true,"secret":false},"value":3},"26-114-0-productId":{"endpoint":0,"commandClass":114,"commandClassName":"Manufacturer Specific","property":"productId","propertyName":"productId","ccVersion":1,"metadata":{"type":"number","readable":true,"writeable":false,"label":"Product ID","min":0,"max":65535,"stateful":true,"secret":false},"value":14},"26-134-0-libraryType":{"endpoint":0,"commandClass":134,"commandClassName":"Version","property":"libraryType","propertyName":"libraryType","ccVersion":1,"metadata":{"type":"number","readable":true,"writeable":false,"label":"Library type","states":{"0":"Unknown","1":"Static Controller","2":"Controller","3":"Enhanced Slave","4":"Slave","5":"Installer","6":"Routing Slave","7":"Bridge Controller","8":"Device under Test","9":"N/A","10":"AV Remote","11":"AV Device"},"stateful":true,"secret":false},"value":6},"26-134-0-protocolVersion":{"endpoint":0,"commandClass":134,"commandClassName":"Version","property":"protocolVersion","propertyName":"protocolVersion","ccVersion":1,"metadata":{"type":"string","readable":true,"writeable":false,"label":"Z-Wave protocol version","stateful":true,"secret":false},"value":"2.78"},"26-134-0-firmwareVersions":{"endpoint":0,"commandClass":134,"commandClassName":"Version","property":"firmwareVersions","propertyName":"firmwareVersions","ccVersion":1,"metadata":{"type":"string[]","readable":true,"writeable":false,"label":"Z-Wave chip firmware versions","stateful":true,"secret":false},"value":["1.23"]}},"endpoints":{"0":{"nodeId":26,"index":0,"deviceClass":{"basic":{"key":4,"label":"Routing Slave"},"generic":{"key":17,"label":"Multilevel Switch"},"specific":{"key":5,"label":"Motor Control Class A"},"mandatorySupportedCCs":[32,38,37,114,134],"mandatoryControlledCCs":[]},"commandClasses":[{"id":38,"name":"Multilevel Switch","version":3,"isSecure":false},{"id":37,"name":"Binary Switch","version":1,"isSecure":false},{"id":114,"name":"Manufacturer Specific","version":1,"isSecure":false},{"id":134,"name":"Version","version":1,"isSecure":false},{"id":49,"name":"Multilevel Sensor","version":3,"isSecure":false},{"id":50,"name":"Meter","version":2,"isSecure":false},{"id":112,"name":"Configuration","version":1,"isSecure":false},{"id":133,"name":"Association","version":1,"isSecure":false}]}}}}}
