Z-Wave JS UI (formerly ZwaveJS2MQTT) and official Z-Wave JS - server/driver differences
I am running Z-Wave JS UI and am seeing lots of different problems with Z-wave.
Could someone please advise, is the Z-Wave Server & Driver within Z-Wave JS UI the same code as the server & driver within Z-Wave JS ?
I would like to try switching, but if effectively the server & driver portions are the same then there may be little point.
Thanks!
They are 100% the same. Only difference is that the server and driver versions can be different since they update independently.
OK thanks, so the server and driver’s are all from the same single source, just could be slightly different versions.
