Since updating Z-Wave JS UI to Server version 13.0.0 today, my thermostat seems to be in a muddle with Celsius and Fahrenheit. In the Z-Wave JS UI web UI I can see this:
In order to answer that, I’d need to know how you installed it. I’ll take a guess and assume you’re using the HAOS add-on. In that case, your only options are 1) rollback to previous version by restoring a backup, or 2) wait until an add-on update is released.
If you’re not using the add-on, you’ll need to provide more info.
Your assumptions are all correct. I’ve rolled back to the previous version. This has restored normality - my system doesn’t think I’m going to freeze to death.
For reference, Z-Wave JS UI v9.16.1 includes an update to Z-Wave JS driver v13.0.1, which includes a fix for a regression having to do with sensor scales (e.g. temperature units).
You can track the latest versions of the components at Z-Wave JS - Which version?, which shows the community add-on is at ZUI v9.16.0. Since v9.16.1 was released just a few hours ago, it will take a little time for the update to propagate to the add-on.
