I’ve got a Yale deadbolt that used to be controllable and now isn’t. I’ve confirmed that I can successfully write to the lock from the zwjs dashboard. Unfortunately, the controls from HA arent working. Is this just my setup or is anyone else seeing this?
This is the error when clicking the unlock botton in the UI and running a lock.unlock service call
Logger: homeassistant.components.websocket_api.http.connection
Source: components/zwave_js/lock.py:112
Integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 3:42:47 PM (1 occurrences)
Last logged: 3:42:47 PM
[139715674006864] Command failed: unknown_error
File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 167, in handle_call_service
await hass.services.async_call(
File "/usr/src/homeassistant/homeassistant/core.py", line 1481, in async_call
task.result()
File "/usr/src/homeassistant/homeassistant/core.py", line 1516, in _execute_service
await handler.job.target(service_call)
File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 213, in handle_service
await self.hass.helpers.service.entity_service_call(
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 658, in entity_service_call
future.result() # pop exception if have
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 726, in async_request_call
await coro
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 695, in _handle_entity_call
await result
File "/usr/src/homeassistant/homeassistant/components/zwave_js/lock.py", line 123, in async_unlock
await self._set_lock_state(STATE_UNLOCKED)
File "/usr/src/homeassistant/homeassistant/components/zwave_js/lock.py", line 112, in _set_lock_state
await self.info.node.async_set_value(
File "/usr/local/lib/python3.8/site-packages/zwave_js_server/model/node.py", line 375, in async_set_value
result = await self.async_send_command(
File "/usr/local/lib/python3.8/site-packages/zwave_js_server/model/node.py", line 354, in async_send_command
result = await self.client.async_send_command(message, **kwargs)
File "/usr/local/lib/python3.8/site-packages/zwave_js_server/client.py", line 73, in async_send_command
return await future
zwave_js_server.exceptions.FailedCommand: Command failed: unknown_error
This is the error when running a lock.open service call
Logger: homeassistant.helpers.script.websocket_api_script
Source: components/lock/__init__.py:115
First occurred: 3:49:43 PM (1 occurrences)
Last logged: 3:49:43 PM
websocket_api script: Error executing script. Unexpected error for call_service at pos 1:
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 363, in _async_step
await getattr(self, handler)()
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 563, in _async_call_service_step
await service_task
task.result()
await coro
await result
File "/usr/src/homeassistant/homeassistant/components/lock/__init__.py", line 119, in async_open
await self.hass.async_add_executor_job(ft.partial(self.open, **kwargs))
File "/usr/local/lib/python3.8/concurrent/futures/thread.py", line 57, in run
File "/usr/src/homeassistant/homeassistant/components/lock/__init__.py", line 115, in open
raise NotImplementedError()
NotImplementedError
