I have a schlage lock it was working great for a while. One day it stopped and stayed down for a few weeks. I ended up restoring my VM to what appeard to be a working state, it actaully seemed like dumb luck. I made a snapshot as soon as it worked.
The next day the lock isn’t responding again. physcailly it is fine
I restored the snapshot, but its still not working.
I’m not even sure where to start on the troubeshooting.
What do you mean by it’s not responding? Is the state just not updating to match, or will it not lock/unlock when flipping the switch in HomeAssistant? I’ve noticed the state of the lock doesn’t update on my setup, but the attributes do. I filed an issue for that: https://github.com/home-assistant/home-assistant/issues/8140
When I say not responding I mean not unlocking, when I click from the webpage and when I unlock from the keypad, the attached automation do not trigger.
Last night after I posted, I messed with it more, specifically, the openzwave secret code. The code wasn’t linked to configuration.yaml directly. It was only in the folder. I saw some configs that had an !included for the code. I’m going to try that next.
