Running 0.65.6 and now the UI does not show the toggle switch to lock/unlock the node. This means I cannot lock or unlock the door remotely without writing an automation. What happened here?
What does the UI show? Is the lock there at all?
Can you still lock and unlock the lock through the services developer tool on the front end?
After a restart, it is there now. It was showing “Unlocked” or “Locked”.
Starting to wonder if this is a UI issue. I just restarted again and it showed up as “Locked”. Refreshed the browser and it now shows with the toggle switch. At the same time, the UI showed the “Automation” group twice until I refreshed.
After upgrading to Hassio 0.65.6 I am also having issues with groups ( under default view only ) appearing twice.
Across restarts the group that is shown twice might change, or there may be more than one group shown twice on the default view.
Running Chrome on Ubuntu.
Issue is NOT present on Chrome on Android.
Have you tried clearing the browser’s cache?
Yep !
That fixed it
