Z-Wave Motion Sensor not reporting status
I recently installed the Z-Wave JS integration and setup a Nortek Z-wave controller with a single motion sensor (NEO Z-Wave Plus Motion Sensor). Initially, reporting was working fine, but when i moved the sensor into the hallway, reporting stopped working. It would report motion detection, but never resets the detection after the timeout period. I removed it and readded it, but got the same thing. Am i missing something with setting or a parameter? On/Off duration is set to 120 seconds. This worked fine in Homeseer. I think i’m just missing something. Any help is greatly appreciated.
Does it report ‘off’ ? Most sensors I’ve seen require turn on the reporting for off state seperatly.
It does report motion, but does not report off when there is no motion.
Exactly, check your device config parameters
Checked and rechecked. Decided to exclude it and add it one more time, and now everything seems to be working as expected. Weird.
