I have 2 Z-Wave roller shades in my bonus room, and with a normal cover group one started moving about a second before the other. A group calls each device separately and the controller waits for each acknowledgement before sending the next command. Z-Wave can send one multicast frame to all of them, but Home Assistant doesn’t do that for groups yet (feature request, architecture discussion), so I wrote a helper that does.
You set it up from the Helpers page like a normal group and get one group entity. Each command goes out as a single frame so everything starts together, and the group state works like Home Assistant’s own groups so you can still see if it’s open or on.
What you can group
- Covers that report a position (open, close, set position, stop)
- Dimmers (on, off, brightness, transition) and Binary Switch lights (on, off)
- Binary Switches (on, off)
- Multilevel Switch fans (on, off, percentage)
Missed frames
Multicast frames aren’t acknowledged and Z-Wave JS marks every device as arrived as soon as the frame is sent, so Home Assistant can’t tell on its own if a device missed it. After the travel time (covers) or a short delay (everything else) the helper asks each device for its real value and re-sends the normal command to any that didn’t get there. If the multicast itself fails it retries once, then falls back to one command per device. The last_delivery and last_verify attributes show what happened.
Limits
- Only non-secure classic Z-Wave devices get multicast. S0 can’t multicast, S2 multicast gives no sync gain, and Long Range nodes can’t share a multicast with mesh nodes. Those devices still work in the group but get the normal one by one command, so if everything you own is on S2 this won’t help you.
- I left out locks, sirens, garage doors and gates on purpose. An unacknowledged frame that some devices miss isn’t worth one second of sync on those.
- The groups don’t offer tilt, light color, effects or fan presets, so set those on the devices.
- It needs Home Assistant 2026.10 or newer with Z-Wave JS.
Testing
I’m running it on my 2 shades, which use Window Covering. Open and close go out as multicast with the delivery check passing, and a multicast stop left both at 24%. The first multicast after a restart failed once with ZW0204 and the next one landed, which is why the retry is there.
Lights, switches and fans have only been through automated tests so far, so if you try those I’d like to hear how it goes.
Install
The HACS default PR is still waiting on review, so for now add it as a custom repository. Go to HACS → ⋮ → Custom repositories, add https://github.com/ljmerza/zwave-multicast-group with type Integration, download it and restart. Then go to Settings → Devices & services → Helpers → Create helper → Z-Wave Multicast Group.
Code and bug reports are here GitHub - ljmerza/zwave-multicast-group: Home Assistant helper: group Z-Wave JS covers, lights, switches or fans and command them with one multicast frame so they act together · GitHub
