Based on it FCC ID doc, it is a Good Way Technology WD6050Z2. I have been able to add it to HA through Z-WAVE JS (although it does show as unknown manufacturer and product), but it does show online. I am although unable to add any devices through the inclusion. I’ve tried using the Z-WAVE JS server add-on and the Z-WAVE JS to MQTT add-on, both have similar issues with adding devices.
Thanks Rick. That was likely what I figured as well, but I thought I’d check with others to get their input. The interesting thing is that this z-wave.net outfit claims their product works with Home Assistant, but any info/support requests I have sent them have have gone nowhere, no response at all. False and misleading claims at this point in my opinion.
For a USB controller, the config file should have no impact on the functionality, it simply provides a descriptive manufacturer and product name. If this USB controller worked in other software (e.g. OZW) then it should work fine with zwave-js, and the problem is likely something else.
