I moved some zwave switches to HA lately and things were working just fine, then I realized a couple days ago that my automations are lagging and I can no longer control my devices when I tried to turn them on/off.
I tried to heal the network but it never got completed. I restarted the hub many times.
I would appreciate if someone can help me.
Logger: homeassistant.core
Source: components/zwave_js/switch.py:70
First occurred: 11:00:50 AM (5 occurrences)
Last logged: 12:27:11 PM
Error executing service: <ServiceCall switch.turn_on (c:b3d195e39d9a9ef20cf2498b198fcfc0): entity_id=[âswitch.main_floor_toilet_lightsâ]>
Error executing service: <ServiceCall switch.turn_on (c:f296f9d57bdd6b7d5deca1e75c839b39): entity_id=[âswitch.garage_entry_lightsâ]>
Error executing service: <ServiceCall switch.turn_on (c:a3f50a20b79165be2c648d0666c7a864): entity_id=[âswitch.garage_entry_lightsâ]>
Error executing service: <ServiceCall switch.turn_on (c:543856ffd80bf77d04c1f6b99a2cf73d): entity_id=[âswitch.garage_entry_lightsâ]>
Error executing service: <ServiceCall switch.turn_on (c:b942df363b9522001a69395908fad33e): entity_id=[âswitch.garage_entry_lightsâ]>
File â/usr/src/homeassistant/homeassistant/core.pyâ, line 1508, in catch_exceptions
await coro_or_task
File â/usr/src/homeassistant/homeassistant/core.pyâ, line 1527, in _execute_service
await handler.job.target(service_call)
File â/usr/src/homeassistant/homeassistant/helpers/entity_component.pyâ, line 213, in handle_service
await self.hass.helpers.service.entity_service_call(
File â/usr/src/homeassistant/homeassistant/helpers/service.pyâ, line 658, in entity_service_call
future.result() # pop exception if have
File â/usr/src/homeassistant/homeassistant/helpers/entity.pyâ, line 843, in async_request_call
await coro
File â/usr/src/homeassistant/homeassistant/helpers/service.pyâ, line 695, in _handle_entity_call
await result
File â/usr/src/homeassistant/homeassistant/components/zwave_js/switch.pyâ, line 70, in async_turn_on
await self.info.node.async_set_value(target_value, True)
File â/usr/local/lib/python3.9/site-packages/zwave_js_server/model/node.pyâ, line 441, in async_set_value
result = await self.async_send_command(
File â/usr/local/lib/python3.9/site-packages/zwave_js_server/model/node.pyâ, line 398, in async_send_command
result = await self.client.async_send_command(message, **kwargs)
File â/usr/local/lib/python3.9/site-packages/zwave_js_server/client.pyâ, line 79, in async_send_command
return await future
zwave_js_server.exceptions.FailedZWaveCommand: Z-Wave error 16: Timeout while waiting for an ACK from the controller
Iâve noticed a heal wonât complete until all battery powered devices are awake. Do you have any battery powered devices? If so try pressing a button on them to wake them so they can participate in updating the neighbors for the heal to complete.
Pretty sure that error actually means that ZWaveJS cannot talk to the controller - check that you used the /dev/serial/by-id/ path and not just /dev/tty-whatever, without having any more information, Iâd guess the machine rebooted and now the serial port you told ZWaveJS to use has changed itâs name so ZWaveJS canât talk to the stick at all.
Thatâs definitely a possibility. Also agree you definitely want the by-id path vs tty.
If the addon canât talk to the controller though, the zwavejs addon usually wonât even start. Does the addon startup and run ok? Generally if itâs an issue talking to the controller you would see logs like in this post Increasing instability in zwave.js?
The logs posted are the homeassistant logs. Any additional logs from the zwavejs addon itself? Its still possible the zstick is just stuck on healing or something else and canât move forward with new commands.
I wouldnât expect a message not being able to make it to the destination to generate a full stack trace though? Itâs not saying that it didnât get an ACK from the end device, itâs saying it didnât get an ACK from the controller itself. That suggests communication has completely stopped. I remember back when people were transitioning to JS from the old ZWave there were people reporting similar issues - and it was finally narrowed down to the USB port not actually providing a stable enough voltage, and people were advised to move to a powered USB hub.
Also is this zwavejs2mqtt or the âofficialâ addon?
Get better logs from Integrations â Configure on ZwaveJS â Logs tab and set it to Silly and post the logs. Use the download button to download the log.
So I ended up updating the HA core server and after that the issue no longer showed. I am not a big fan of upgrading to fix but I had to do this one since I needed the automation to work.
