Driver: Failed to open the serial port: Error: I/O error setting custom baud rate of 115200 (ZW0100)
This leads me to believe it’s something to do with the VM/USB settings. However, I hadn’t made any changes (or even touched) the z-stick hardware, or the VM serial port settings in ages.
The Hardware / Software
Running Home Assistant OS as a VM in virtualbox on Windows Host.
Z-Stick shows up in host device manager on COM4.
Virtualbox serial port settings are pointing to Port Number: COM4 and Path/Address: COM4
What I did right before it went down
Ran several updates in a row
zwavejs
zwavejs ui
Side note: Should I be running both of these? I thought I only needed one, but I assume UI installs regular JS on it’s own. Should I disable the non UI add on?
Home Assistant Core from 2023.09.x to 2023.10.2
Of Note
When I noticed this issue, I assumed the USB hub I had the Z-stick plugged into died, so I removed it from the equation. That changed the serial port from COM3 to COM4. Prior to all this, everything was running fine on COM3, but the z-wave network stopped working before I made these changes.
At this point I’m stumped. HassOS doesn’t see the Z-Stick, but I don’t know why.
I actually got it up and running again, but not really sure how. Had a long back and forth on discord with someone very helpful and we tried several things that all seemingly didn’t work. That’s until I had moved on and rebooted one last time for other reasons, when it came back on, it was good to go.
You weren’t kidding about a train wreck. I’m sure my next reboot will kill the network again. Joy.
