Newbe here. Just install HA version 2022.12.8. Install Z-WaveJS and Aeotec Gen 5 usb stick yesterday.
All was working fine. Then suddenly the one automation to turn on an office light stopped working. Tracked down the following log
Blockquote2022-12-29T21:35:13.230Z CNTRLR [Node 026] The node is alive.
2022-12-29T21:35:13.231Z CNTRLR [Node 026] The node is ready to be used
2022-12-29T21:35:13.232Z CNTRLR All nodes are ready to be used
2022-12-29T21:35:13.289Z CNTRLR « [Node 026] ping successful
2022-12-29T21:35:17.408Z CNTRLR [Node 007] The node did not respond after 1 attempts, it is presumed dead
2022-12-29T21:35:17.423Z CNTRLR [Node 007] ping failed: Failed to send the command after 1 attempts (Status No
Ack) (ZW0204)
2022-12-29T21:35:17.429Z CNTRLR [Node 007] Interview attempt (1/5) failed, node is dead.
Starting logging event forwarder at info level
Stopping logging event forwarder
2022-12-29T21:40:01.816Z CNTRLR » [Node 007] pinging the node…
2022-12-29T21:40:05.996Z CNTRLR [Node 007] The node did not respond after 1 attempts, it is presumed dead
2022-12-29T21:40:06.001Z CNTRLR [Node 007] ping failed: Failed to send the command after 1 attempts (Status No
Ack) (ZW0204)
2022-12-29T21:40:06.001Z CNTRLR [Node 007] Skipping heal because the node is not responding.
Question - did the Aeotec Gen 5 usb stick fail? (It is about two years old - but it has been in a box - first time I have used it.
I have restarted HA, and I have rebooted the Odroid N2+ I am running HA on. This did not fix the problem.
Your help is appreciated.
