I just upgraded my docker to 0.70.0 and I have one node in my Z-Wave where it won’t load. So if I go into the configuration and refresh the node it seems to work however if I restart HA this problem occurs again. It is always the same node. If I go back to a previous version I do not have this issue. What is going on here?
Post your OZW_Log.txt of when it’s not loading.
I think there is known issue due to docker OS got changed. It is already written up here.
https://github.com/home-assistant/home-assistant/issues/14680
It just seems weird that it is always node 4 and I have other devices that are exactly the same that don’t have this issue.
