So I thought I had my Z-wave issues sorted. Turns out my Zooz ZSE40 sensor is not quite all there.
It shows up in the node list and integrations. Has good signal strength, but is only showing its binary_sensor as an entity. Temp, humidity, luminance; all those other sensors are missing.
The parameters show up in the OZW xml file (below). Just looks like Home Assistant is missing it. Any way to force the entities to re-add? It’s done this through several restarts.
Thanks.
<Node id="3" name="" location="" basic="4" generic="7" specific="1" roletype="6" devicetype="3079" nodetype="0" type="Notification Sensor" listening="false" frequentListening="false" beaming="true" routing="true" max_baud_rate="40000" version="4" query_stage="Probe">
<Manufacturer id="27a" name="Zooz">
<Product type="2021" id="2101" name="ZSE40 4-in-1 sensor" />
</Manufacturer>
<CommandClasses>
<CommandClass id="32" name="COMMAND_CLASS_BASIC" version="1" request_flags="4">
<Instance index="1" />
<Value type="byte" genre="basic" instance="1" index="0" label="Basic" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0" />
</CommandClass>
<CommandClass id="48" name="COMMAND_CLASS_SENSOR_BINARY" version="1">
<Value type="bool" genre="user" instance="1" index="0" label="Sensor" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="False" />
</CommandClass>
<CommandClass id="49" name="COMMAND_CLASS_SENSOR_MULTILEVEL" version="7" innif="true">
<Value type="decimal" genre="user" instance="1" index="1" label="Temperature" units="F" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="69.11" />
<Value type="decimal" genre="user" instance="1" index="3" label="Luminance" units="%" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="13.93" />
<Value type="decimal" genre="user" instance="1" index="5" label="Relative Humidity" units="%" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="69.18" />
</CommandClass>
<CommandClass id="90" name="COMMAND_CLASS_DEVICE_RESET_LOCALLY" version="1" request_flags="4" innif="true">
</CommandClass>
<CommandClass id="94" name="COMMAND_CLASS_ZWAVEPLUS_INFO" version="1" request_flags="4" innif="true">
<Value type="byte" genre="system" instance="1" index="0" label="ZWave+ Version" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="1" />
<Value type="short" genre="system" instance="1" index="1" label="InstallerIcon" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-32768" max="32767" value="3079" />
<Value type="short" genre="system" instance="1" index="2" label="UserIcon" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-32768" max="32767" value="3079" />
</CommandClass>
<CommandClass id="112" name="COMMAND_CLASS_CONFIGURATION" version="1" request_flags="4" innif="true">
<Value type="list" genre="config" instance="1" index="1" label="Temperature Scale" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="1" vindex="1" size="1">
<Help>Temperature scale (Celsius or Fahrenheit (default)).</Help>
<Item label="Celsius" value="0" />
<Item label="Fahrenheit" value="1" />
</Value>
<Value type="byte" genre="config" instance="1" index="2" label="Temperature Change Notif" units="0.1 degree" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="1" max="50" value="10">
<Help>Minimum temperature change that will trigger a report to the controller, in 0.1 degrees. 10 = 1.0 degrees (default).</Help>
</Value>
<Value type="byte" genre="config" instance="1" index="3" label="Humidity Change Notif" units="%" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="1" max="50" value="10">
<Help>Minimum humidity change (%) that will trigger a report to the controller. 10 = 10% (default).</Help>
</Value>
<Value type="byte" genre="config" instance="1" index="4" label="Light Change Notif" units="%" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="5" max="50" value="10">
<Help>Minimum light sensor change (%) that will trigger a report to the controller. 10 = 10% (default).</Help>
</Value>
<Value type="byte" genre="config" instance="1" index="5" label="Motion Sensor Trigger Interval" units="second" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="15" max="60" value="15">
<Help>After initial motion, sensor will wait this long before reporting again. 15 = 15 seconds (default); 60 = 60 seconds.</Help>
</Value>
<Value type="list" genre="config" instance="1" index="6" label="Motion Sensor Sensitivity" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="1" max="7" vindex="3" size="1">
<Help>Motion sensor sensitivity.</Help>
<Item label="Very High" value="1" />
<Item label="High" value="2" />
<Item label="Somewhat High" value="3" />
<Item label="Normal" value="4" />
<Item label="Somewhat Low" value="5" />
<Item label="Low" value="6" />
<Item label="Very Low" value="7" />
</Value>
<Value type="list" genre="config" instance="1" index="7" label="LED indicator mode" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="1" max="4" vindex="0" size="1">
<Help>Color LED behavior. 1 = LED off; 2 = pulsing light for temperature, flashing light for motion (high battery drain); 3 = flashing light for temperature and motion (default); 4 = flashing light for motion.</Help>
<Item label="Off" value="1" />
<Item label="Pulse Temp/Flash Motion" value="2" />
<Item label="Flash Temp & Motion" value="3" />
<Item label="Flash Motion" value="4" />
</Value>
</CommandClass>
<CommandClass id="113" name="COMMAND_CLASS_ALARM" version="4" request_flags="2" innif="true">
<Value type="byte" genre="user" instance="1" index="0" label="Alarm Type" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="7" />
<Value type="byte" genre="user" instance="1" index="1" label="Alarm Level" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0" />
<Value type="byte" genre="user" instance="1" index="2" label="SourceNodeId" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0" />
<Value type="byte" genre="user" instance="1" index="10" label="Burglar" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0" />
<Value type="byte" genre="user" instance="1" index="12" label="System" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0" />
<Value type="byte" genre="user" instance="1" index="13" label="Emergency" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0" />
<Value type="byte" genre="user" instance="1" index="14" label="Clock" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0" />
</CommandClass>
<CommandClass id="114" name="COMMAND_CLASS_MANUFACTURER_SPECIFIC" version="1" request_flags="4" innif="true">
</CommandClass>
<CommandClass id="115" name="COMMAND_CLASS_POWERLEVEL" version="1" request_flags="4" innif="true">
<Value type="list" genre="system" instance="1" index="0" label="Powerlevel" units="dB" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="0" size="1">
<Item label="Normal" value="0" />
<Item label="-1dB" value="1" />
<Item label="-2dB" value="2" />
<Item label="-3dB" value="3" />
<Item label="-4dB" value="4" />
<Item label="-5dB" value="5" />
<Item label="-6dB" value="6" />
<Item label="-7dB" value="7" />
<Item label="-8dB" value="8" />
<Item label="-9dB" value="9" />
</Value>
<Value type="byte" genre="system" instance="1" index="1" label="Timeout" units="seconds" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0" />
<Value type="button" genre="system" instance="1" index="2" label="Set Powerlevel" units="" read_only="false" write_only="true" verify_changes="false" poll_intensity="0" min="0" max="0" />
<Value type="byte" genre="system" instance="1" index="3" label="Test Node" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0" />
<Value type="list" genre="system" instance="1" index="4" label="Test Powerlevel" units="dB" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="0" size="1">
</Value>
<Value type="short" genre="system" instance="1" index="5" label="Frame Count" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="-32768" max="32767" value="0" />
<Value type="button" genre="system" instance="1" index="6" label="Test" units="" read_only="false" write_only="true" verify_changes="false" poll_intensity="0" min="0" max="0" />
<Value type="button" genre="system" instance="1" index="7" label="Report" units="" read_only="false" write_only="true" verify_changes="false" poll_intensity="0" min="0" max="0" />
<Value type="list" genre="system" instance="1" index="8" label="Test Status" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="0" size="1">
<Item label="Failed" value="0" />
<Item label="Success" value="1" />
<Item label="In Progress" value="2" />
</Value>
<Value type="short" genre="system" instance="1" index="9" label="Acked Frames" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-32768" max="32767" value="0" />
</CommandClass>
<CommandClass id="128" name="COMMAND_CLASS_BATTERY" version="1" request_flags="4" innif="true">
<Value type="byte" genre="user" instance="1" index="0" label="Battery Level" units="%" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="100" />
</CommandClass>
<CommandClass id="132" name="COMMAND_CLASS_WAKE_UP" version="2" request_flags="2" innif="true">
<Value type="int" genre="system" instance="1" index="0" label="Wake-up Interval" units="Seconds" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="43200" />
<Value type="int" genre="system" instance="1" index="1" label="Minimum Wake-up Interval" units="Seconds" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="600" />
<Value type="int" genre="system" instance="1" index="2" label="Maximum Wake-up Interval" units="Seconds" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="604800" />
<Value type="int" genre="system" instance="1" index="3" label="Default Wake-up Interval" units="Seconds" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="43200" />
<Value type="int" genre="system" instance="1" index="4" label="Wake-up Interval Step" units="Seconds" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="600" />
</CommandClass>
<CommandClass id="133" name="COMMAND_CLASS_ASSOCIATION" version="1" request_flags="4" innif="true">
<Associations num_groups="1">
<Group index="1" max_associations="5" label="Lifeline" auto="true">
<Node id="1" />
</Group>
</Associations>
</CommandClass>
<CommandClass id="134" name="COMMAND_CLASS_VERSION" version="1" request_flags="4" innif="true">
<Value type="string" genre="system" instance="1" index="0" label="Library Version" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="3" />
<Value type="string" genre="system" instance="1" index="1" label="Protocol Version" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="4.54" />
<Value type="string" genre="system" instance="1" index="2" label="Application Version" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="17.09" />
</CommandClass>
</CommandClasses>
</Node>
