When I moved from Raspbian to the new Hass.io I found out, that even I copied over my configuration, that I need to rename every Z-Wave device again. At the time I had a screenshot from ozw control panel so I had a reference witch node ID is which sensor, because I named the device in the panel.
Know I fear, if i loose HA and my config dosn’t include the Renamed Z-Wave device that I don’t know anylonger which NodeID is which device.
Can I export the renamed node list? or is there a way to safe it? So I don’t have to rename it again?
