Z-Wave Node Management - "Node config options" doesn't work with new install on 0.68.1
When I try to open the section for “Node config options” after selecting any node I do not get anything in the drop down box.
All other sections work and display values correctly such as Node Values and Node Group Associations.
I am running Home Assistant 0.68.1 on a new install on MacOS. I was running previously on RasPi 3 but too many crashes and slow performance after adding new Z-Wave switches I have moved back to running this way.
I have tried completely rebuilding by renaming the .homeassistant directory and restarting but same behaviour.
Previous versions that were upgraded to 0.68.1 this was not a problem so I am wondering if it is a recent problem because I have installed new from this version rather than an upgrade?
Thanks.
I have downgraded to older version 0.67.1 and same issue.
I think now I have only seen this “Node config options” work under hassio on the raspi
I have verified I can update options by using the developer “zwave.set_config_parameter” service.
I needed to set Option 80 to 1 on an aeotec nano switch so it uses hail to notify of changes.
So this really seems to be a web interface issue that is fine when you use hassio on raspi (it works) vs running on MacOS (it doesn’t work)
