Hello everyone!
Currently on:
~ $ ha info
arch: aarch64
channel: stable
hassos: "3.13"
homeassistant: 0.109.6
hostname: hassio
logging: info
machine: raspberrypi3-64
supervisor: "222"
supported_arch:
- aarch64
- armv7
- armhf
and I have a Z-Wave node that stopped working so I removed the physical node but it still shows up as Ready:
Just to show that the node is indeed gone I went to Z-Wave Node Management, selected the node and clicked: Test Node. The log shows this operation timed out (because the node does not exist anymore):
2020-05-14 08:34:47.871 Info, Node020, NoOperation::Set - Routing=true
2020-05-14 08:34:47.872 Detail, Node020, Queuing (NoOp) NoOperation_Set (Node=20): 0x01, 0x09, 0x00, 0x13, 0x14, 0x02, 0x00, 0x00, 0x25, 0xe2, 0x34
2020-05-14 08:34:47.872 Info, Node020, Sending (NoOp) message (Callback ID=0xe2, Expected Reply=0x13) - NoOperation_Set (Node=20): 0x01, 0x09, 0x00, 0x13, 0x14, 0x02, 0x00, 0x00, 0x25, 0xe2, 0x34
2020-05-14 08:34:57.874 Error, Node020, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-05-14 08:34:57.874 Detail, Node020, Removing current message
2020-05-14 08:34:57.874 Detail, Node020, Notification: Notification - TimeOut
I’m also trying to remove the node by selecting the node under: Developer Tools --> STATES and setting the: State attributes (YAML, optional) to: is_failed: true
Then back to Z-Wave Node Management, select the node and click REMOVE FAILED NODE
It does not appear this is working because I see this error in the logs:
2020-05-14 08:49:21.612 Detail, Node020, Queuing (Controller) Remove Failed Node
2020-05-14 08:49:21.613 Info, ControllerCommand_RemoveFailedNode
2020-05-14 08:49:21.613 Detail, contrlr, Queuing (Command) ControllerCommand_RemoveFailedNode: 0x01, 0x05, 0x00, 0x61, 0x14, 0xe4, 0x6b
2020-05-14 08:49:21.613 Detail, Notification: ControllerCommand - Starting
2020-05-14 08:49:21.615 Detail,
2020-05-14 08:49:21.615 Info, contrlr, Sending (Command) message (Callback ID=0xe4, Expected Reply=0x61) - ControllerCommand_RemoveFailedNode: 0x01, 0x05, 0x00, 0x61, 0x14, 0xe4, 0x6b
2020-05-14 08:49:22.615 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-05-14 08:49:22.615 Detail, contrlr, Removing current message
2020-05-14 08:49:22.616 Detail, contrlr, Notification: Notification - TimeOut
2020-05-14 08:49:22.622 Detail, Notification: ControllerCommand - Error - Failed
Would anyone know what’s going on and how to correct this? Also, why does the node show up as Ready when it is clearly not even physically present and has long since been buried in a landfill?
