My SD-card started to malfunction so, before the card died completely, I did a new clean install off Home Assistant .0.86.4 on a new SD-card. Then I copied all files from my daily backup into the .homeassistant-folder and everything is working fine.
My only but severe problem: None of all my 30+ z-wave nodes can be found, except of the Aeon-stick itself.
- I have not touched my Aeon Z-wave stick or any of the nodes.
- my zwcfg_*.xml file looks fine, all the nodes are there.
- In the Z-wave config, I can se my Aeon stick, but no other nodes are available.
- On the states page, I can only se that same Aeon stick.
The strange thing is, when I put my old (and about to die) SD-card in my Rpi, I can see all my Z-wave nodes again. Replacing the old SD-card with the new one, All Z-wave nodes, except the Aeon stick, are gone. Therefore, I guess the problem has to be software related.
All ideas on how to solve this issue are welcome.
