Hello everyone,
I am not sure if this questions goes here. But here it goes,
As we know Z-wave mesh, can only uphold up to 256 Devices. Does anyone know if all those removed devices Count for that total number?
Thank you
Hello everyone,
Thank you
no only the ones that are added it won’t use removed node numbers until it hit the end then it will go back and start filling in the removed ones
Another little tidbit I discovered with Zwave-JS is you can have more then one server I put two usb stick on my home assistant profile and it see and talks with them both so technically that is over 500 devices LOL not sure how much of a train wreck that would become
OMG!!! AMAZING!!! thank you! because i am going to have well over 300 zwave devices, if Z-wave is the way to go… since now thread is coming on board…
but if your case, why do you have 2?
at the moment I don’t really need to, as I am only at 60 devices so far but I was curious if it was possible and I thought about setting up a seperate network for the devices in my garage but have not decided yet but I like the option though
