Z-wave non-secure vs secure devices
Which devices are non-secure and which are secure devices in Z-wave. What do you use in Z-Wave Network Management for Add a z-wave device ADD NODE SECURE OR ADD NODE.
You’ll want to add any locks you have as secure (ADD NODE SECURE).
AFAIK, all z-wave plus can do secure. I used secure mode when I could early on but after unrelated problem I rebuilt using non-secure to keep things easy; sometimes I had trouble using secured mode. Right now only device in network with secure mode is 1 door lock. Please don’t hack my house. :wink:
Thanks for your answer :slight_smile: and your :house_with_garden: is safe.
does this work with aeotech z stick?
I use an Aeotech Z-stick with a secure node (Schlage lock)
Thanks for confirming.
This is the model I use (older gen)
product_name: DSA02203 Z-Stick S2
How many sensors do you have with the Schlage lock? Is it the Schlage Connect?
Thanks, I have them all showing up now.
