Z-wave not starting
I am using
SkyConnect v1.0 - /dev/serial/by-id/usb-Nabu_Casa_SkyConnect_v1.0_903cbfb04fd5ec11a64722b1a1ca919a-if00-port0, s/n: 903cbfb04fd5ec11a64722b1a1ca919a - Nabu Casa - 10C4:EA60
Z-Wave JS
Current version: 0.9.0
I am running HA on an old laptop
and geting this log
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/config.sh
[14:54:22] INFO: Both 'network_key' and 's0_legacy_key' are set and match. All ok.
[14:54:23] INFO: Soft-reset set to automatic
[14:54:23] INFO: Virtual Machine not detected, enabling soft-reset
cont-init: info: /etc/cont-init.d/config.sh exited 0
cont-init: info: running /etc/cont-init.d/structure.sh
cont-init: info: /etc/cont-init.d/structure.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun zwave_js (no readiness notification)
s6-rc: info: service legacy-services successfully started
[14:54:24] INFO: Successfully send discovery information to Home Assistant.
2024-12-11T19:54:25.642Z DRIVER   ███████╗        ██╗    ██╗  █████╗  ██╗   ██╗ ███████╗          ██╗ ███████╗
2024-12-11T19:54:25.644Z DRIVER   version 13.10.3
2024-12-11T19:54:26.671Z CONFIG   version 13.10.3
2024-12-11T19:54:27.101Z CNTRLR   querying Serial API capabilities...
2024-12-11T19:54:28.262Z CNTRLR   Failed to execute controller command after 1/3 attempts. Scheduling next try i
                                  n 100 ms.
2024-12-11T19:54:29.365Z CNTRLR   Failed to execute controller command after 2/3 attempts. Scheduling next try i
                                  n 1100 ms.
2024-12-11T19:54:31.474Z DRIVER   Failed to initialize the driver: ZWaveError: Timeout while waiting for an ACK
                                  from the controller (ZW0200)
                                      at Driver.sendMessage (/usr/src/node_modules/zwave-js/src/lib/driver/Drive
                                  r.ts:5907:23)
                                      at ZWaveController.queryCapabilities (/usr/src/node_modules/zwave-js/src/l
                                  ib/controller/Controller.ts:1144:37)
                                      at Driver.initializeControllerAndNodes (/usr/src/node_modules/zwave-js/src
                                  /lib/driver/Driver.ts:1537:46)
                                      at Immediate.<anonymous> (/usr/src/node_modules/zwave-js/src/lib/driver/Dr
                                  iver.ts:1338:16)
Error in driver ZWaveError: Failed to initialize the driver: ZWaveError: Timeout while waiting for an ACK from the controller (ZW0200)
    at Driver.sendMessage (/usr/src/node_modules/zwave-js/src/lib/driver/Driver.ts:5907:23)
    at ZWaveController.queryCapabilities (/usr/src/node_modules/zwave-js/src/lib/controller/Controller.ts:1144:37)
    at Driver.initializeControllerAndNodes (/usr/src/node_modules/zwave-js/src/lib/driver/Driver.ts:1537:46)
    at Immediate.<anonymous> (/usr/src/node_modules/zwave-js/src/lib/driver/Driver.ts:1338:16) (ZW0100)
    at Immediate.<anonymous> (/usr/src/node_modules/zwave-js/src/lib/driver/Driver.ts:1358:6) {
  code: 100,
  context: undefined,
  transactionSource: undefined
Shutting down
[19:54:31] WARNING: Halt add-on
s6-rc: info: service legacy-services: stopping
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
You are attempting to use a Zigbee controller (Home Assistant connect AKA SkyConnect) with Z-Wave, which will never work. I think you want ZHA or zigbee2mqtt.
