talder
November 25, 2023, 5:28pm
1
I was running HASSOS on a NUC for four years before i switched to Homey in august. Now i want to go back to Home Assistant because Homey does not cut it for me.
Before the switch to Homey, everything was running fine.
I did a clean install off HASSOS on the same NUC it was running on in august. After the basic setup, i have installed Z-WAVE JS UI and configured my Aeotec z-stick gen 5, but i can not longer add z-wave devices. Inclusion mode runs fine, but does not detect anything. I have over 50 z-wave devices and tried different ones. I also tried my new z-stick 700 stick, but it’s the same outcome.
I have tried different things so far, like installing onto an other NUC, tried the z-strick 5 and 700 serie on z-wave PC controller (they work flawless), disabled soft reset, ec…
Also nothing is shown in the debug logs, you see the inclusion command executed and then aborted by time-out. No errors whatsoever.
My Home Assistant version is 2023.11.3
OS 11.1
Z-WAVE JS UI 3.0.2
700 serie stick v7.17.2
Does anybody has the same problem with z-wave on a new installation? Anybody has an idea what could be wrong here?
Thx,
Tim
NathanCu
(Nathan Curtis)
November 25, 2023, 5:33pm
2
Did you exclude your device before you tried to include it? If not the ZWave device still thinks it’s connected the old network.
You can run a general device exclude from any ZWave coordinator so run exclude from HA. Exclude rhe device then try to include it.
talder
November 25, 2023, 5:36pm
3
Yes, i have 2 test devices that i reset manually, so they are not linked to another controller. Also exclusion does not work, times out after the default 30 sec.
NathanCu
(Nathan Curtis)
November 25, 2023, 5:39pm
4
If the device is not ZWave plus a factory reset isn’t enough. You also need to exclude. Exclude on reset wasn’t added to the ZWave spec until plus.
How is your coordinator connected to what’s running HA. (direct in usb port? USB hub?)
(Hint: were finding you should be using an extension cord at least)
talder
November 25, 2023, 5:44pm
5
I’m testing currently with a fibaro smoke sensor (z-wave plus) reset the device on yellow light. Worked in the past, so i think this should be fine. The coordinator is connected directly to the USB port on the NUC, but as you mentioned i tried also an extension cord, heck even tried an active USB extension cord with both coordinators.
NathanCu
(Nathan Curtis)
November 25, 2023, 5:49pm
6
It’s time to start grabbing debug logs then.
You’ll want to keep the extension cord - especially if you have an SSD in that nuc. (SSD noise on the USB bus is usually the actual problem the extension solves with ZWave sticks, with zigbee it’s an order of magnitude worse.)
I assume you’re also addressing the stick by-id instead of using the default virtual USB port?
talder
November 25, 2023, 5:58pm
7
Yes, by ID, but checking the homey, i see there are also some issues. Does the Homey 2023 could interfere with the z-stick 700 by any means? I’ve tried to pull the plug from Homey, but dit not see any difference, but Homey can also not add any devices, very strange and Homey does also have many TX errors. Only thing changes over the past weeks is the addition of a Ubiquiti Dream Machine. But why is this happening right now…thats the question…
NathanCu
(Nathan Curtis)
November 25, 2023, 6:02pm
8
Zwave networks generally don’t interfere with each other like that. If you don’t need it I’d kill it… But. That’s probably not the issue.
talder
November 25, 2023, 7:29pm
9
Ok, i’ve included the JS log. Near the end you will find a try for inclusion.
2023-11-25T19:26:20.371Z DRIVER ███████╗ ██╗ ██╗ █████╗ ██╗ ██╗ ███████╗ ██╗ ███████╗
2023-11-25T19:26:20.373Z DRIVER version 12.3.0
2023-11-25T19:26:20.374Z DRIVER
2023-11-25T19:26:20.375Z DRIVER starting driver...
2023-11-25T19:26:20.375Z DRIVER opening serial port /dev/serial/by-id/usb-Silicon_Labs_CP2102N_USB_to_UART_Bri
dge_Controller_6a74257de784ed11b238c89f9d1cc348-if00-port0
2023-11-25T19:26:20.391Z DRIVER serial port opened
2023-11-25T19:26:20.394Z SERIAL » 0x15 (1 bytes)
2023-11-25T19:26:21.410Z DRIVER loading configuration...
2023-11-25T19:26:21.426Z CONFIG Using external configuration dir /data/db
2023-11-25T19:26:21.427Z CONFIG version 12.3.0
2023-11-25T19:26:22.522Z DRIVER beginning interview...
2023-11-25T19:26:22.525Z DRIVER added request handler for AddNodeToNetwork (0x4a)...
1 registered
2023-11-25T19:26:22.526Z DRIVER added request handler for RemoveNodeFromNetwork (0x4b)...
1 registered
2023-11-25T19:26:22.526Z DRIVER added request handler for ReplaceFailedNode (0x63)...
1 registered
2023-11-25T19:26:22.527Z DRIVER added request handler for SerialAPIStarted (0x0a)...
1 registered
2023-11-25T19:26:22.529Z CNTRLR querying Serial API capabilities...
2023-11-25T19:26:22.801Z SERIAL » 0x01030007fb (5 bytes)
2023-11-25T19:26:22.804Z DRIVER » [REQ] [GetSerialApiCapabilities]
2023-11-25T19:26:22.814Z SERIAL « [ACK] (0x06)
2023-11-25T19:26:22.819Z SERIAL « 0x012b01070711000000040004f6873e88cf2bc04ffbd7fde00700008000808680b (45 bytes)
a05007000002e7fc000000006
2023-11-25T19:26:22.822Z SERIAL » [ACK] (0x06)
2023-11-25T19:26:22.825Z DRIVER « [RES] [GetSerialApiCapabilities]
payload: 0x0711000000040004f6873e88cf2bc04ffbd7fde00700008000808680ba0500700
0002e7fc0000000
2023-11-25T19:26:22.835Z CNTRLR received API capabilities:
firmware version: 7.17
manufacturer ID: 0x00
product type: 0x04
product ID: 0x04
supported functions:
· GetSerialApiInitData (0x02)
· SetApplicationNodeInformation (0x03)
· GetControllerCapabilities (0x05)
· SetSerialApiTimeouts (0x06)
· GetSerialApiCapabilities (0x07)
· SoftReset (0x08)
· GetProtocolVersion (0x09)
· SerialAPIStarted (0x0a)
· SerialAPISetup (0x0b)
· SetRFReceiveMode (0x10)
· FUNC_ID_ZW_SEND_NODE_INFORMATION (0x12)
· SendData (0x13)
· SendDataMulticast (0x14)
· GetControllerVersion (0x15)
· SendDataAbort (0x16)
· FUNC_ID_ZW_GET_RANDOM (0x1c)
· GetControllerId (0x20)
· UNKNOWN_FUNC_MEMORY_GET_BYTE (0x21)
· UNKNOWN_FUNC_MEMORY_PUT_BYTE (0x22)
· UNKNOWN_FUNC_MEMORY_GET_BUFFER (0x23)
· UNKNOWN_FUNC_MEMORY_PUT_BUFFER (0x24)
· EnterBootloader (0x27)
· UNKNOWN_FUNC_UNKNOWN_0x28 (0x28)
· GetNVMId (0x29)
· ExtNVMReadLongBuffer (0x2a)
· ExtNVMReadLongByte (0x2c)
· NVMOperations (0x2e)
· undefined (0x37)
· undefined (0x38)
· UNKNOWN_FUNC_ClearNetworkStats (0x39)
· UNKNOWN_FUNC_GetNetworkStats (0x3a)
· GetBackgroundRSSI (0x3b)
· undefined (0x3c)
· UNKNOWN_FUNC_RemoveNodeIdFromNetwork (0x3f)
· GetNodeProtocolInfo (0x41)
· HardReset (0x42)
· FUNC_ID_ZW_REPLICATION_COMMAND_COMPLETE (0x44)
· FUNC_ID_ZW_REPLICATION_SEND_DATA (0x45)
· AssignReturnRoute (0x46)
· DeleteReturnRoute (0x47)
· RequestNodeNeighborUpdate (0x48)
· ApplicationUpdateRequest (0x49)
· AddNodeToNetwork (0x4a)
· RemoveNodeFromNetwork (0x4b)
· FUNC_ID_ZW_CONTROLLER_CHANGE (0x4d)
· AssignPriorityReturnRoute (0x4f)
· FUNC_ID_ZW_SET_LEARN_MODE (0x50)
· AssignSUCReturnRoute (0x51)
· FUNC_ID_ZW_REQUEST_NETWORK_UPDATE (0x53)
· SetSUCNodeId (0x54)
· DeleteSUCReturnRoute (0x55)
· GetSUCNodeId (0x56)
· UNKNOWN_FUNC_SEND_SUC_ID (0x57)
· AssignPrioritySUCReturnRoute (0x58)
· FUNC_ID_ZW_EXPLORE_REQUEST_INCLUSION (0x5e)
· undefined (0x5f)
· RequestNodeInfo (0x60)
· RemoveFailedNode (0x61)
· IsFailedNode (0x62)
· ReplaceFailedNode (0x63)
· GetRoutingInfo (0x80)
· UNKNOWN_FUNC_LOCK_ROUTE_RESPONSE (0x90)
· GetPriorityRoute (0x92)
· SetPriorityRoute (0x93)
· UNKNOWN_FUNC_UNKNOWN_0x98 (0x98)
· FUNC_ID_SERIAL_API_SLAVE_NODE_INFO (0xa0)
· FUNC_ID_ZW_SEND_SLAVE_NODE_INFO (0xa2)
· FUNC_ID_ZW_SET_SLAVE_LEARN_MODE (0xa4)
· FUNC_ID_ZW_GET_VIRTUAL_NODES (0xa5)
· FUNC_ID_ZW_IS_VIRTUAL_NODE (0xa6)
· BridgeApplicationCommand (0xa8)
· SendDataBridge (0xa9)
· SendDataMulticastBridge (0xab)
· UNKNOWN_FUNC_GET_LIBRARY_TYPE (0xbd)
· UNKNOWN_FUNC_SEND_TEST_FRAME (0xbe)
· UNKNOWN_FUNC_GET_PROTOCOL_STATUS (0xbf)
· UNKNOWN_FUNC_UNKNOWN_0xD2 (0xd2)
· UNKNOWN_FUNC_UNKNOWN_0xD3 (0xd3)
· UNKNOWN_FUNC_UNKNOWN_0xD4 (0xd4)
· undefined (0xd6)
· Shutdown (0xd9)
· undefined (0xda)
· undefined (0xdb)
· undefined (0xdc)
· undefined (0xdd)
· undefined (0xde)
· undefined (0xdf)
· undefined (0xe7)
· undefined (0xe8)
2023-11-25T19:26:22.836Z CNTRLR querying version info...
2023-11-25T19:26:22.845Z SERIAL » 0x01030015e9 (5 bytes)
2023-11-25T19:26:22.845Z DRIVER » [REQ] [GetControllerVersion]
2023-11-25T19:26:22.851Z SERIAL « [ACK] (0x06)
2023-11-25T19:26:22.854Z SERIAL « 0x011001155a2d5761766520372e3137000791 (18 bytes)
2023-11-25T19:26:22.855Z SERIAL » [ACK] (0x06)
2023-11-25T19:26:22.856Z DRIVER « [RES] [GetControllerVersion]
payload: 0x5a2d5761766520372e31370007
2023-11-25T19:26:22.860Z CNTRLR received version info:
controller type: Bridge Controller
library version: Z-Wave 7.17
2023-11-25T19:26:22.860Z CNTRLR querying protocol version info...
2023-11-25T19:26:22.866Z SERIAL » 0x01030009f5 (5 bytes)
2023-11-25T19:26:22.867Z DRIVER » [REQ] [GetProtocolVersion]
2023-11-25T19:26:22.873Z SERIAL « [ACK] (0x06)
2023-11-25T19:26:22.875Z SERIAL « 0x01190109000711020196303030303030303030303030303030306d (27 bytes)
2023-11-25T19:26:22.876Z SERIAL » [ACK] (0x06)
2023-11-25T19:26:22.878Z DRIVER « [RES] [GetProtocolVersion]
payload: 0x00071102019630303030303030303030303030303030
2023-11-25T19:26:22.881Z CNTRLR received protocol version info:
protocol type: Z-Wave
protocol version: 7.17.2
appl. framework build no.: 406
git commit hash: 30303030303030303030303030303030
2023-11-25T19:26:22.882Z CNTRLR querying serial API setup capabilities...
2023-11-25T19:26:22.888Z SERIAL » 0x0104000b01f1 (6 bytes)
2023-11-25T19:26:22.889Z DRIVER » [REQ] [SerialAPISetup]
command: GetSupportedCommands
payload: 0x01
2023-11-25T19:26:22.895Z SERIAL « [ACK] (0x06)
2023-11-25T19:26:22.897Z SERIAL « 0x0116010b01fe3e0103000100000001000000000000000121 (24 bytes)
2023-11-25T19:26:22.899Z SERIAL » [ACK] (0x06)
2023-11-25T19:26:22.901Z DRIVER « [RES] [SerialAPISetup]
payload: 0xfe3e01030001000000010000000000000001
2023-11-25T19:26:22.905Z CNTRLR supported serial API setup commands:
· GetSupportedCommands
· SetTxStatusReport
· SetLRMaximumTxPower
· SetPowerlevel
· GetLRMaximumTxPower
· GetPowerlevel
· GetMaximumPayloadSize
· GetLRMaximumPayloadSize
· GetRFRegion
· SetRFRegion
· SetNodeIDType
2023-11-25T19:26:22.905Z CNTRLR Querying configured RF region...
2023-11-25T19:26:22.910Z SERIAL » 0x0104000b20d0 (6 bytes)
2023-11-25T19:26:22.912Z DRIVER » [REQ] [SerialAPISetup]
command: GetRFRegion
payload: 0x20
2023-11-25T19:26:22.916Z SERIAL « [ACK] (0x06)
2023-11-25T19:26:22.917Z SERIAL « 0x0105010b20fe2e (7 bytes)
2023-11-25T19:26:22.918Z SERIAL » [ACK] (0x06)
2023-11-25T19:26:22.920Z DRIVER « [RES] [SerialAPISetup]
region: Unknown
2023-11-25T19:26:22.923Z CNTRLR The controller is using RF region Unknown
2023-11-25T19:26:22.924Z CNTRLR Switching serial API to 16-bit node IDs...
2023-11-25T19:26:22.929Z SERIAL » 0x0105000b800273 (7 bytes)
2023-11-25T19:26:22.930Z DRIVER » [REQ] [SerialAPISetup]
command: SetNodeIDType
node ID type: 16 bit
2023-11-25T19:26:22.934Z SERIAL « [ACK] (0x06)
2023-11-25T19:26:22.936Z SERIAL « 0x0105010b800171 (7 bytes)
2023-11-25T19:26:22.937Z SERIAL » [ACK] (0x06)
2023-11-25T19:26:22.939Z DRIVER « [RES] [SerialAPISetup]
success: true
2023-11-25T19:26:22.942Z CNTRLR Switching to 16-bit node IDs successful
2023-11-25T19:26:22.942Z CNTRLR querying controller IDs...
2023-11-25T19:26:22.946Z SERIAL » 0x01030020dc (5 bytes)
2023-11-25T19:26:22.947Z DRIVER » [REQ] [GetControllerId]
2023-11-25T19:26:22.952Z SERIAL « [ACK] (0x06)
2023-11-25T19:26:22.953Z SERIAL « 0x01090120caa8694f000192 (11 bytes)
2023-11-25T19:26:22.955Z SERIAL » [ACK] (0x06)
2023-11-25T19:26:22.956Z DRIVER « [RES] [GetControllerId]
home ID: 0xcaa8694f
own node ID: 1
2023-11-25T19:26:22.959Z CNTRLR received controller IDs:
home ID: 0xcaa8694f
own node ID: 1
2023-11-25T19:26:22.962Z DRIVER all queues idle
2023-11-25T19:26:22.982Z CNTRLR Performing soft reset...
2023-11-25T19:26:22.985Z DRIVER all queues busy
2023-11-25T19:26:22.988Z SERIAL » 0x01030008f4 (5 bytes)
2023-11-25T19:26:22.989Z DRIVER » [REQ] [SoftReset]
2023-11-25T19:26:22.993Z SERIAL « [ACK] (0x06)
2023-11-25T19:26:22.996Z CNTRLR Waiting for the controller to reconnect...
2023-11-25T19:26:22.998Z DRIVER all queues idle
2023-11-25T19:26:24.217Z SERIAL « 0x0116000a03000102070c5e748a87855a568f989f6c5500f7 (24 bytes)
2023-11-25T19:26:24.221Z SERIAL » [ACK] (0x06)
2023-11-25T19:26:24.224Z DRIVER « [REQ] [SerialAPIStarted]
wake up reason: WatchdogReset
watchdog enabled: false
generic device class: 0x02
specific device class: 0x07
always listening: false
supports Long Range: false
2023-11-25T19:26:24.227Z CNTRLR reconnected and restarted
2023-11-25T19:26:24.228Z CNTRLR Switching serial API to 16-bit node IDs...
2023-11-25T19:26:24.232Z DRIVER all queues busy
2023-11-25T19:26:24.238Z SERIAL » 0x0105000b800273 (7 bytes)
2023-11-25T19:26:24.240Z DRIVER » [REQ] [SerialAPISetup]
2023-11-25T19:26:24.245Z SERIAL « [ACK] (0x06)
2023-11-25T19:26:24.246Z SERIAL « 0x0105010b800171 (7 bytes)
2023-11-25T19:26:24.248Z SERIAL » [ACK] (0x06)
2023-11-25T19:26:24.249Z DRIVER « [RES] [SerialAPISetup]
success: true
2023-11-25T19:26:24.253Z CNTRLR Switching to 16-bit node IDs successful
2023-11-25T19:26:24.254Z DRIVER all queues idle
2023-11-25T19:26:24.269Z CNTRLR supported Z-Wave features:
· SmartStart
2023-11-25T19:26:24.270Z CNTRLR querying controller capabilities...
2023-11-25T19:26:24.273Z DRIVER all queues busy
2023-11-25T19:26:24.277Z SERIAL » 0x01030005f9 (5 bytes)
2023-11-25T19:26:24.278Z DRIVER » [REQ] [GetControllerCapabilities]
2023-11-25T19:26:24.283Z SERIAL « [ACK] (0x06)
2023-11-25T19:26:24.285Z SERIAL « 0x010401053cc3 (6 bytes)
2023-11-25T19:26:24.287Z SERIAL » [ACK] (0x06)
2023-11-25T19:26:24.288Z DRIVER « [RES] [GetControllerCapabilities]
payload: 0x3c
2023-11-25T19:26:24.291Z CNTRLR received controller capabilities:
controller role: primary
is the SUC: true
started this network: true
SIS is present: true
was real primary: true
2023-11-25T19:26:24.292Z CNTRLR Enabling TX status report...
2023-11-25T19:26:24.298Z SERIAL » 0x0105000b02ff0c (7 bytes)
2023-11-25T19:26:24.299Z DRIVER » [REQ] [SerialAPISetup]
command: SetTxStatusReport
enabled: true
2023-11-25T19:26:24.303Z SERIAL « [ACK] (0x06)
2023-11-25T19:26:24.305Z SERIAL « 0x0105010b0201f3 (7 bytes)
2023-11-25T19:26:24.306Z SERIAL » [ACK] (0x06)
2023-11-25T19:26:24.308Z DRIVER « [RES] [SerialAPISetup]
success: true
2023-11-25T19:26:24.312Z CNTRLR Enabling TX status report successful...
2023-11-25T19:26:24.312Z CNTRLR finding SUC...
2023-11-25T19:26:24.317Z SERIAL » 0x01030056aa (5 bytes)
2023-11-25T19:26:24.318Z DRIVER » [REQ] [GetSUCNodeId]
2023-11-25T19:26:24.322Z SERIAL « [ACK] (0x06)
2023-11-25T19:26:24.323Z SERIAL « 0x010501560001ac (7 bytes)
2023-11-25T19:26:24.325Z SERIAL » [ACK] (0x06)
2023-11-25T19:26:24.326Z DRIVER « [RES] [GetSUCNodeId]
payload: 0x0001
2023-11-25T19:26:24.329Z CNTRLR This is the SUC
2023-11-25T19:26:24.329Z CNTRLR querying additional controller information...
2023-11-25T19:26:24.333Z SERIAL » 0x01030002fe (5 bytes)
2023-11-25T19:26:24.334Z DRIVER » [REQ] [GetSerialApiInitData]
2023-11-25T19:26:24.342Z SERIAL « [ACK] (0x06)
2023-11-25T19:26:24.343Z SERIAL « 0x0125010209081d010000000000000000000000000000000000000000000000000 (39 bytes)
00000000700c3
2023-11-25T19:26:24.345Z SERIAL » [ACK] (0x06)
2023-11-25T19:26:24.346Z DRIVER « [RES] [GetSerialApiInitData]
payload: 0x09081d01000000000000000000000000000000000000000000000000000000000
700
2023-11-25T19:26:24.350Z CNTRLR received additional controller information:
Z-Wave API version: 9 (legacy)
Z-Wave chip type: EFR32ZG14 / ZGM130S
node type Controller
controller is the SIS: true
controller supports timers: false
nodes in the network: 1
2023-11-25T19:26:24.363Z DRIVER Cache file for homeId 0xcaa8694f found, attempting to restore the network from
cache...
2023-11-25T19:26:24.385Z DRIVER all queues idle
2023-11-25T19:26:24.425Z CNTRLR [Node 001] Embedded device config loaded
2023-11-25T19:26:24.429Z DRIVER Restoring the network from cache was successful!
2023-11-25T19:26:24.435Z CNTRLR [Node 001] [translateValueEvent: metadata updated]
commandClass: Manufacturer Specific
endpoint: undefined
property: manufacturerId
propertyKey: undefined
internal: false
secret: false
event source: undefined
2023-11-25T19:26:24.436Z CNTRLR [Node 001] [Manufacturer Specific] manufacturerId: metadata updated
2023-11-25T19:26:24.437Z CNTRLR [Node 001] [translateValueEvent: metadata updated]
is root endpoint: true
is application CC: false
should hide root values: false
2023-11-25T19:26:24.438Z CNTRLR [Node 001] [translateValueEvent: metadata updated]
endpoint: undefined
property: productType
internal: false
secret: false
2023-11-25T19:26:24.438Z CNTRLR [Node 001] [Manufacturer Specific] productType: metadata updated
2023-11-25T19:26:24.439Z CNTRLR [Node 001] [translateValueEvent: metadata updated]
2023-11-25T19:26:24.440Z CNTRLR [Node 001] [translateValueEvent: metadata updated]
endpoint: undefined
property: productId
internal: false
secret: false
2023-11-25T19:26:24.440Z CNTRLR [Node 001] [Manufacturer Specific] productId: metadata updated
2023-11-25T19:26:24.441Z CNTRLR [Node 001] [translateValueEvent: metadata updated]
2023-11-25T19:26:24.442Z CNTRLR [Node 001] [translateValueEvent: value updated]
endpoint: undefined
internal: false
secret: false
talder
November 25, 2023, 7:30pm
10
2023-11-25T19:26:24.443Z CNTRLR [Node 001] [~] [Manufacturer Specific] manufacturerId: 0 => 0
2023-11-25T19:26:24.444Z CNTRLR [Node 001] [translateValueEvent: value updated]
2023-11-25T19:26:24.446Z CNTRLR [Node 001] [translateValueEvent: value updated]
endpoint: undefined
internal: false
secret: false
2023-11-25T19:26:24.446Z CNTRLR [Node 001] [~] [Manufacturer Specific] productType: 4 => 4
2023-11-25T19:26:24.448Z CNTRLR [Node 001] [translateValueEvent: value updated]
endpoint: undefined
property: productId
internal: false
secret: false
2023-11-25T19:26:24.448Z CNTRLR [Node 001] [~] [Manufacturer Specific] productId: 4 => 4
2023-11-25T19:26:24.450Z CNTRLR [Node 001] [translateValueEvent: metadata updated]
commandClass: Version
endpoint: undefined
property: firmwareVersions
internal: false
secret: false
2023-11-25T19:26:24.450Z CNTRLR [Node 001] [Version] firmwareVersions: metadata updated
2023-11-25T19:26:24.451Z CNTRLR [Node 001] [translateValueEvent: metadata updated]
2023-11-25T19:26:24.451Z CNTRLR [Node 001] [translateValueEvent: value updated]
endpoint: undefined
internal: false
secret: false
2023-11-25T19:26:24.452Z CNTRLR [Node 001] [~] [Version] firmwareVersions: 7.17 => 7.17
2023-11-25T19:26:24.452Z CNTRLR [Node 001] [translateValueEvent: value updated]
2023-11-25T19:26:24.454Z CNTRLR [Node 001] [translateValueEvent: metadata updated]
endpoint: undefined
property: zWaveProtocolVersion
internal: false
secret: false
2023-11-25T19:26:24.454Z CNTRLR [Node 001] [Version] zWaveProtocolVersion: metadata updated
2023-11-25T19:26:24.455Z CNTRLR [Node 001] [translateValueEvent: metadata updated]
2023-11-25T19:26:24.455Z CNTRLR [Node 001] [translateValueEvent: value updated]
endpoint: undefined
internal: false
secret: false
2023-11-25T19:26:24.456Z CNTRLR [Node 001] [~] [Version] zWaveProtocolVersion: "7.17.2" => "7.17.2"
2023-11-25T19:26:24.456Z CNTRLR [Node 001] [translateValueEvent: value updated]
2023-11-25T19:26:24.457Z CNTRLR [Node 001] [translateValueEvent: metadata updated]
endpoint: undefined
property: sdkVersion
internal: false
secret: false
2023-11-25T19:26:24.457Z CNTRLR [Node 001] [Version] sdkVersion: metadata updated
2023-11-25T19:26:24.458Z CNTRLR [Node 001] [translateValueEvent: value updated]
endpoint: undefined
internal: false
secret: false
2023-11-25T19:26:24.459Z CNTRLR [Node 001] [~] [Version] sdkVersion: "7.17.2" => "7.17.2"
2023-11-25T19:26:24.459Z CNTRLR [Node 001] [translateValueEvent: value updated]
2023-11-25T19:26:24.459Z CNTRLR Interview completed
2023-11-25T19:26:24.460Z DRIVER Network key for S0 configured, enabling S0 security manager...
2023-11-25T19:26:24.463Z DRIVER At least one network key for S2 configured, enabling S2 security manager...
2023-11-25T19:26:24.473Z DRIVER driver ready
2023-11-25T19:26:24.479Z DRIVER Checking for configuration updates...
2023-11-25T19:26:24.515Z CNTRLR [Node 001] The node is alive.
2023-11-25T19:26:24.629Z CNTRLR [Node 001] The node is ready to be used
2023-11-25T19:26:24.630Z CNTRLR All nodes are ready to be used
2023-11-25T19:26:24.632Z CNTRLR Interviewing nodes and/or determining their status:
2023-11-25T19:26:24.638Z DRIVER all queues busy
2023-11-25T19:26:24.644Z SERIAL » 0x0104000b08f8 (6 bytes)
2023-11-25T19:26:24.644Z DRIVER » [REQ] [SerialAPISetup]
command: GetPowerlevel
payload: 0x08
2023-11-25T19:26:24.695Z SERIAL « [ACK] (0x06)
2023-11-25T19:26:24.696Z SERIAL « 0x0106010b080002f9 (8 bytes)
2023-11-25T19:26:24.698Z SERIAL » [ACK] (0x06)
2023-11-25T19:26:24.700Z DRIVER « [RES] [SerialAPISetup]
normal powerlevel: 0.0 dBm
output power at 0 dBm: 0.2 dBm
2023-11-25T19:26:24.706Z SERIAL » 0x0104000b20d0 (6 bytes)
2023-11-25T19:26:24.706Z DRIVER » [REQ] [SerialAPISetup]
payload: 0x20
2023-11-25T19:26:24.723Z SERIAL « [ACK] (0x06)
2023-11-25T19:26:24.724Z SERIAL « 0x0105010b20fe2e (7 bytes)
2023-11-25T19:26:24.725Z SERIAL » [ACK] (0x06)
2023-11-25T19:26:24.786Z DRIVER « [RES] [SerialAPISetup]
region: Unknown
2023-11-25T19:26:24.789Z DRIVER all queues idle
2023-11-25T19:26:25.528Z DRIVER Usage statistics sent - next transmission scheduled in 23 hours.
2023-11-25T19:26:26.879Z DRIVER No configuration update available...
2023-11-25T19:26:29.796Z DRIVER all queues busy
2023-11-25T19:26:29.806Z SERIAL » 0x0103003bc7 (5 bytes)
2023-11-25T19:26:29.807Z DRIVER » [REQ] [GetBackgroundRSSI]
2023-11-25T19:26:29.812Z SERIAL « [ACK] (0x06)
2023-11-25T19:26:29.815Z SERIAL « 0x0107013b9bcece7f26 (9 bytes)
2023-11-25T19:26:29.817Z SERIAL » [ACK] (0x06)
2023-11-25T19:26:29.820Z DRIVER « [RES] [GetBackgroundRSSI]
channel 0: -101 dBm
channel 1: -50 dBm
channel 2: -50 dBm
2023-11-25T19:26:29.828Z DRIVER all queues idle
2023-11-25T19:26:54.241Z CNTRLR Starting inclusion process with strategy Default...
2023-11-25T19:26:54.249Z DRIVER all queues busy
2023-11-25T19:26:54.260Z SERIAL » 0x0105004ac10170 (7 bytes)
2023-11-25T19:26:54.263Z DRIVER » [REQ] [AddNodeToNetwork]
node type: Any
high power: true
network wide: true
callback id: 1
2023-11-25T19:26:54.268Z SERIAL « [ACK] (0x06)
2023-11-25T19:26:54.273Z SERIAL « 0x0108004a0101000000bd (10 bytes)
2023-11-25T19:26:54.276Z SERIAL » [ACK] (0x06)
2023-11-25T19:26:54.279Z DRIVER « [REQ] [AddNodeToNetwork]
status: Ready
callback id: 1
2023-11-25T19:26:54.286Z CNTRLR The controller is now ready to add nodes
2023-11-25T19:26:54.294Z DRIVER all queues idle
2023-11-25T19:26:59.795Z DRIVER all queues busy
2023-11-25T19:26:59.801Z SERIAL » 0x0103003bc7 (5 bytes)
2023-11-25T19:26:59.802Z DRIVER » [REQ] [GetBackgroundRSSI]
2023-11-25T19:26:59.807Z SERIAL « [ACK] (0x06)
2023-11-25T19:26:59.810Z SERIAL « 0x0107013b9bcece7f26 (9 bytes)
2023-11-25T19:26:59.812Z SERIAL » [ACK] (0x06)
2023-11-25T19:26:59.815Z DRIVER « [RES] [GetBackgroundRSSI]
channel 0: -101 dBm
channel 1: -50 dBm
channel 2: -50 dBm
2023-11-25T19:26:59.820Z DRIVER all queues idle
2023-11-25T19:27:29.793Z DRIVER all queues busy
2023-11-25T19:27:29.799Z SERIAL » 0x0103003bc7 (5 bytes)
2023-11-25T19:27:29.800Z DRIVER » [REQ] [GetBackgroundRSSI]
2023-11-25T19:27:29.806Z SERIAL « [ACK] (0x06)
2023-11-25T19:27:29.808Z SERIAL « 0x0107013b9bcece7f26 (9 bytes)
2023-11-25T19:27:29.811Z SERIAL » [ACK] (0x06)
2023-11-25T19:27:29.815Z DRIVER « [RES] [GetBackgroundRSSI]
channel 0: -101 dBm
channel 1: -50 dBm
channel 2: -50 dBm
2023-11-25T19:27:29.821Z DRIVER all queues idle
2023-11-25T19:27:54.240Z CNTRLR stopping inclusion process...
2023-11-25T19:27:54.244Z DRIVER all queues busy
2023-11-25T19:27:54.250Z SERIAL » 0x0105004ac50277 (7 bytes)
2023-11-25T19:27:54.251Z DRIVER » [REQ] [AddNodeToNetwork]
action: Stop
high power: true
network wide: true
callback id: 2
2023-11-25T19:27:54.257Z SERIAL « [ACK] (0x06)
2023-11-25T19:27:54.260Z SERIAL « 0x0108004a0206000000b9 (10 bytes)
2023-11-25T19:27:54.263Z SERIAL » [ACK] (0x06)
2023-11-25T19:27:54.266Z DRIVER « [REQ] [AddNodeToNetwork]
status: Done
callback id: 2
2023-11-25T19:27:54.271Z CNTRLR The inclusion process was stopped
2023-11-25T19:27:54.278Z DRIVER all queues idle
2023-11-25T19:27:59.793Z DRIVER all queues busy
2023-11-25T19:27:59.800Z SERIAL » 0x0103003bc7 (5 bytes)
2023-11-25T19:27:59.801Z DRIVER » [REQ] [GetBackgroundRSSI]
2023-11-25T19:27:59.809Z SERIAL « [ACK] (0x06)
2023-11-25T19:27:59.811Z SERIAL « 0x0107013b9bcece7f26 (9 bytes)
2023-11-25T19:27:59.815Z SERIAL » [ACK] (0x06)
2023-11-25T19:27:59.818Z DRIVER « [RES] [GetBackgroundRSSI]
channel 0: -101 dBm
channel 1: -50 dBm
channel 2: -50 dBm
2023-11-25T19:27:59.823Z DRIVER all queues idle
Just a word of advice, don’t use Silly logging unless a developer specifically asks for it. It has too much noise. Debug is good enough.
talder:
region: Unknown
First of all, you won’t be able to include anything with a region set to “Unknown”. Make sure you set your region to the correct location and power levels. Second, the power levels look suspicious, I’ve never seen configuration of 0.0 / 0.2. You can send an email to Aeotec to ask what their recommendation is, but according to the screenshot at the bottom of this page , the values are 9.9 / -6.5.
You can set both settings in either the ZUI control panel under the controller entry, or preferably in the Z-Wave settings. The latter method ensures the region and power levels are persisted after firmware upgrades, which has a habit of resetting them.
Also, your background RSSI is terrible. This could be related to the power level settings, or even lack of a USB extension cable. Make sure the controller is not located in something like a server cage that blocks RF. You should look at these values after you’ve made changes and see if they improve:
channel 0: -101 dBm
channel 1: -50 dBm
channel 2: -50 dBm
I don’t remember which channels are which frequencies, but with background RSSI at -50 dBm it may be a challenge to include anything, since everything is going to appear as noise. For 700-series all 3 channels should be around -100 dBm.
talder
November 25, 2023, 10:55pm
12
hi,
thank you for your reply.
The region was set in the z-wave settings, i also fixed the power levels now, but i can not change them at the controller level, these values:
they always reset back to there defaults seen in the screenshot.
Also when i restart the JS integration the power levels could not be set and region stay at unknown:
2023-11-25T22:47:05.106Z CNTRLR Querying configured RF region...
2023-11-25T22:47:05.111Z SERIAL » 0x0104000b20d0 (6 bytes)
2023-11-25T22:47:05.112Z DRIVER » [REQ] [SerialAPISetup]
payload: 0x20
2023-11-25T22:47:05.116Z SERIAL « [ACK] (0x06)
2023-11-25T22:47:05.118Z SERIAL « 0x0105010b20fe2e (7 bytes)
2023-11-25T22:47:05.119Z SERIAL » [ACK] (0x06)
2023-11-25T22:47:05.121Z DRIVER « [RES] [SerialAPISetup]
region: Unknown
2023-11-25T22:47:05.123Z CNTRLR The controller is using RF region Unknown
2023-11-25T22:47:05.124Z CNTRLR Querying configured powerlevel...
2023-11-25T22:47:05.129Z SERIAL » 0x0104000b08f8 (6 bytes)
2023-11-25T22:47:05.130Z DRIVER » [REQ] [SerialAPISetup]
payload: 0x08
2023-11-25T22:47:05.134Z SERIAL « [ACK] (0x06)
2023-11-25T22:47:05.136Z SERIAL « 0x0106010b080002f9 (8 bytes)
2023-11-25T22:47:05.137Z SERIAL » [ACK] (0x06)
2023-11-25T22:47:05.139Z DRIVER « [RES] [SerialAPISetup]
2023-11-25T22:47:05.142Z CNTRLR Current powerlevel 0 dBm (0.2 dBm) differs from desired powerlevel 9.9 dBm (-6
.5 dBm), configuring it...
2023-11-25T22:47:05.147Z SERIAL » 0x0106000b0463bf2a (8 bytes)
2023-11-25T22:47:05.148Z DRIVER » [REQ] [SerialAPISetup]
command: SetPowerlevel
normal powerlevel: 9.9 dBm
output power at 0 dBm: -6.5 dBm
2023-11-25T22:47:05.152Z SERIAL « [ACK] (0x06)
2023-11-25T22:47:05.154Z SERIAL « 0x0105010b0400f4 (7 bytes)
2023-11-25T22:47:05.155Z SERIAL » [ACK] (0x06)
2023-11-25T22:47:05.157Z DRIVER « [RES] [SerialAPISetup]
success: false
2023-11-25T22:47:05.159Z CNTRLR The controller response indicated failure after 1/3 attempts. Scheduling next
try in 100 ms.
2023-11-25T22:47:05.261Z DRIVER » [REQ] [SerialAPISetup]
2023-11-25T22:47:05.261Z SERIAL » 0x0106000b0463bf2a (8 bytes)
2023-11-25T22:47:05.267Z SERIAL « [ACK] (0x06)
2023-11-25T22:47:05.268Z SERIAL « 0x0105010b0400f4 (7 bytes)
2023-11-25T22:47:05.269Z SERIAL » [ACK] (0x06)
2023-11-25T22:47:05.271Z DRIVER « [RES] [SerialAPISetup]
success: false
2023-11-25T22:47:05.273Z CNTRLR The controller response indicated failure after 2/3 attempts. Scheduling next
try in 1100 ms.
2023-11-25T22:47:06.376Z DRIVER » [REQ] [SerialAPISetup]
2023-11-25T22:47:06.376Z SERIAL » 0x0106000b0463bf2a (8 bytes)
2023-11-25T22:47:06.382Z SERIAL « [ACK] (0x06)
2023-11-25T22:47:06.385Z SERIAL « 0x0105010b0400f4 (7 bytes)
2023-11-25T22:47:06.386Z SERIAL » [ACK] (0x06)
2023-11-25T22:47:06.388Z DRIVER « [RES] [SerialAPISetup]
success: false
2023-11-25T22:47:06.398Z CNTRLR Changing the powerlevel failed!
2023-11-25T22:47:06.399Z CNTRLR Switching serial API to 16-bit node IDs...
2023-11-25T22:47:06.408Z SERIAL » 0x0105000b800273 (7 bytes)
2023-11-25T22:47:06.410Z DRIVER » [REQ] [SerialAPISetup]
2023-11-25T22:47:06.415Z SERIAL « [ACK] (0x06)
2023-11-25T22:47:06.417Z SERIAL « 0x0105010b800171 (7 bytes)
2023-11-25T22:47:06.420Z SERIAL » [ACK] (0x06)
2023-11-25T22:47:06.422Z DRIVER « [RES] [SerialAPISetup]
success: true
2023-11-25T22:47:06.426Z CNTRLR Switching to 16-bit node IDs successful
2023-11-25T22:47:06.428Z CNTRLR querying controller IDs...
2023-11-25T22:47:06.435Z SERIAL » 0x01030020dc (5 bytes)
2023-11-25T22:47:06.436Z DRIVER » [REQ] [GetControllerId]
2023-11-25T22:47:06.441Z SERIAL « [ACK] (0x06)
2023-11-25T22:47:06.443Z SERIAL « 0x01090120caa8694f000192 (11 bytes)
2023-11-25T22:47:06.446Z SERIAL » [ACK] (0x06)
2023-11-25T22:47:06.448Z DRIVER « [RES] [GetControllerId]
home ID: 0xcaa8694f
own node ID: 1
2023-11-25T22:47:06.452Z CNTRLR received controller IDs:
home ID: 0xcaa8694f
own node ID: 1
2023-11-25T22:47:06.457Z DRIVER all queues idle
2023-11-25T22:47:06.488Z CNTRLR Performing soft reset...
2023-11-25T22:47:06.491Z DRIVER all queues busy
2023-11-25T22:47:06.496Z SERIAL » 0x01030008f4 (5 bytes)
2023-11-25T22:47:06.497Z DRIVER » [REQ] [SoftReset]
2023-11-25T22:47:06.500Z SERIAL « [ACK] (0x06)
2023-11-25T22:47:06.504Z CNTRLR Waiting for the controller to reconnect...
2023-11-25T22:47:06.506Z DRIVER all queues idle
2023-11-25T22:47:07.725Z SERIAL « 0x0116000a03000102070c5e748a87855a568f989f6c5500f7 (24 bytes)
2023-11-25T22:47:07.729Z SERIAL » [ACK] (0x06)
2023-11-25T22:47:07.732Z DRIVER « [REQ] [SerialAPIStarted]
2023-11-25T22:47:07.736Z CNTRLR reconnected and restarted
2023-11-25T22:47:07.736Z CNTRLR Switching serial API to 16-bit node IDs...
2023-11-25T22:47:07.742Z DRIVER all queues busy
2023-11-25T22:47:07.748Z SERIAL » 0x0105000b800273 (7 bytes)
2023-11-25T22:47:07.749Z DRIVER » [REQ] [SerialAPISetup]
I have a vague recollection that some sticks had problems like this until after performing a firmware upgrade. However, 7.17.2 is the version that Aeotec currently recommends. You may need to get support from them.
The Gen5 wouldn’t have any of these problems though, so something else is going on for that one.
talder
November 26, 2023, 11:13am
14
Well, i’ve got the same problem with the Gen5, region and powerlevels fail to set. Thinking it’s a Z-WAVE JS UI bug…
talder
November 26, 2023, 11:22am
15
May to mention, both stick’s work fine in PC controller, can add and remove devices just perfectly
talder
November 27, 2023, 7:22pm
16
I have found the culprit of this issue. One of my Qubino z-wave DIN-rail dimmers has malfunctioned and disrupted the hole z-wave network. Found out the hard way by resetting all z-wave devices/config, and eliminated all grid powered device’s. Removing this bad boy and my controller was accepted new devices again.
Grtz,
Tim
