I believe I was able to get it working. Navigated to /config/.storage/core.config_entries changed “usb_path”: “/dev/ttyACM0” to “usb_path”: “/dev/ttyAMA0”
I also changed the configuration.yaml file to read:
The path setting in configuration.yaml is irrelevant once it has been imported into the core.config_entries file. Changing it afterwards has no effect, until you delete the integration (Configuration -> Integrations), then restart HA, where it will be re-imported again.
I don’t have any locks, but I would expect the process would be to go to the ‘add node secure’ option in configuration > zwave panel. After that, you can use the zwave panel to set options on the device.
