Z-Wave: Philio PAT02-A not reporting water leak
All,
I am running the lastest
Home Assistant 2022.12.5
Supervisor 2022.11.2
Operating System 9.4
Frontend 20221213.0 - latest
I just recognized that the PAT02-A by Philio Technology Corp reports temperature and humidity just fine, but does not report a water leakage.
So if I trigger the flood sensor with water, it starts beeping, but it does not send any information beyond that.
This device is obviously supported by z-wave JS:
Z-Wave JS Config DB Browser (zwave-js.io)
There are some disabled entities I have activated, but these do not report anything as well.
Any help would be greatly appreciated
EDIT:
This is still not solved yet (see also: Z-wave flood sensor alarm not working - Configuration / Z-Wave - Home Assistant Community (home-assistant.io))
So, whenever someone finds a solution…
