Z-Wave Presumed Dead Caused by Distance?
Having issues with my Zooz Zen25 Double plug. I keep having intermittent issues trying to controller the outlet connected to my lamp. sometimes it works some times it does not. Checking the log I see the presumed dead message. I am trying to sort out WHY.
I am running Hassio on RPI4 with a HUSBZB-1. I have tried heal, test and soft reset of network. Only thing that makes it come back is to ignore it and then it works again…maybe. So I was wondering if I need to add in a repeater somewhere. I live in an apartment so the pi is not far from the outlet, separated by a wall and about 30 feet. Additionally, my Pi case is an Argon40, which is metal. So could that be an issue too? I did add my network key into the options.xml (<Option name=“NetworkKey” value=) as some suggested that would help. Still no luck. So far this is pretty much the only thing I have in HA right now, and it only works half the time. Bit frustrating.
