Z-wave questions - Smart Switch Secure as repeater?
I have 2 Aeon Labs Smart Gen 5 switches.
One is added as non-secure (from what I see of configuration) and the second is now added as secure.
My questions are
  1. In order to function as a repeater, do they switches need to be added as secure?
My first switch (the insecure one) works, the binary switch created, I can turn on and off teh ports.
The second switch (the one I’m working on now) was finally added as a secure switch but there is no binary switch in HA so I cannot test the on/off capabilities.
Here are the two snippets from the ozw confi
Secure Aeon Switch
	<Node id="47" name="" location="" basic="4" generic="16" specific="1" roletype="5" devicetype="1792" nodetype="0" type="Binary Power Switch" listening="true" frequentListening="false" beaming="true" routing="true" max_baud_rate="40000" version="4" secured="true" refreshonnodeinfoframe="false" query_stage="Complete">
		<Manufacturer id="86" name="AEON Labs">
			<Product type="103" id="60" name="ZW096 Smart Switch 6" />
		</Manufacturer>
		<CommandClasses>
			<CommandClass id="32" name="COMMAND_CLASS_BASIC" version="1" request_flags="4" mapping="37">
				<Instance index="1" />
			</CommandClass>
			<CommandClass id="37" name="COMMAND_CLASS_SWITCH_BINARY" version="1" request_flags="4" innif="true">
				<Value type="bool" genre="user" instance="1" index="0" label="Switch" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="False" />
			</CommandClass>
			<CommandClass id="38" name="COMMAND_CLASS_SWITCH_MULTILEVEL" version="2" innif="true">
				<Value type="byte" genre="user" instance="1" index="0" label="Level" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0" />
				<Value type="button" genre="user" instance="1" index="1" label="Bright" units="" read_only="false" write_only="true" verify_changes="false" poll_intensity="0" min="0" max="0" />
				<Value type="button" genre="user" instance="1" index="2" label="Dim" units="" read_only="false" write_only="true" verify_changes="false" poll_intensity="0" min="0" max="0" />
				<Value type="bool" genre="system" instance="1" index="3" label="Ignore Start Level" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="True" />
				<Value type="byte" genre="system" instance="1" index="4" label="Start Level" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0" />
			</CommandClass>
			<CommandClass id="39" name="COMMAND_CLASS_SWITCH_ALL" version="1" request_flags="4" innif="true">
				<Value type="list" genre="system" instance="1" index="0" label="Switch All" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="0" size="1">
					<Item label="Disabled" value="0" />
					<Item label="Off Enabled" value="1" />
					<Item label="On Enabled" value="2" />
					<Item label="On and Off Enabled" value="255" />
				</Value>
			</CommandClass>
			<CommandClass id="50" name="COMMAND_CLASS_METER" version="3" request_flags="2" innif="true">
				<Value type="decimal" genre="user" instance="1" index="0" label="Unknown" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="0.0" />
			</CommandClass>
			<CommandClass id="51" name="COMMAND_CLASS_COLOR" version="1" request_flags="2" innif="true">
				<Value type="int" genre="system" instance="1" index="2" label="Color Channels" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="0" />
			</CommandClass>
			<CommandClass id="90" name="COMMAND_CLASS_DEVICE_RESET_LOCALLY" version="1" request_flags="4" after_mark="true" innif="true">
			</CommandClass>
			<CommandClass id="94" name="COMMAND_CLASS_ZWAVEPLUS_INFO" version="1" request_flags="4" innif="true">
				<Value type="byte" genre="system" instance="1" index="0" label="ZWave+ Version" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="1" />
				<Value type="short" genre="system" instance="1" index="1" label="InstallerIcon" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-32768" max="32767" value="1792" />
				<Value type="short" genre="system" instance="1" index="2" label="UserIcon" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-32768" max="32767" value="1792" />
			</CommandClass>
			<CommandClass id="112" name="COMMAND_CLASS_CONFIGURATION" version="1" request_flags="4" innif="true">
				<Value type="list" genre="config" instance="1" index="3" label="Current Overload Protection" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="1" vindex="1" size="1">
					<Help>Load will be closed when the Current overruns (US 15.5A, Others 16.2) for more than 2 minutes</Help>
					<Item label="Deactivate Overload Protection" value="0" />
					<Item label="Active Overload Protection (Default)" value="1" />
				</Value>
				<Value type="list" genre="config" instance="1" index="20" label="Output Load Status" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="2" vindex="0" size="1">
					<Help>Configure the output load status after re-power on.</Help>
					<Item label="Last status (Default)" value="0" />
					<Item label="Always on" value="1" />
					<Item label="Always off" value="2" />
				</Value>
				<Value type="list" genre="config" instance="1" index="21" label="RGB Led Color for Testing" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="1" max="4" vindex="0" size="1">
					<Help>Configure the RGB Led Color for Testing</Help>
					<Item label="Reserved" value="1" />
					<Item label="Red" value="2" />
					<Item label="Green" value="3" />
					<Item label="Blue" value="4" />
				</Value>
				<Value type="list" genre="config" instance="1" index="80" label="Notification status" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="2" vindex="0" size="1">
					<Help>Defines the automated status notification of an associated device when status changes</Help>
					<Item label="Nothing (Default)" value="0" />
					<Item label="Hail" value="1" />
					<Item label="Basic" value="2" />
				</Value>
				<Value type="list" genre="config" instance="1" index="81" label="Configure the state of the LED" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="1" vindex="0" size="1">
					<Item label="The LED will follow the status (on/off) of its load. (Default)" value="0" />
					<Item label="When the state of the Switch changes, the LED will follow the status (on/off) of its load, but the LED will turn off after 5 seconds." value="1" />
					<Item label="Night Light Mode" value="2" />
				</Value>
				<Value type="int" genre="config" instance="1" index="83" label="Night Light Color" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="16777215" value="14524637">
					<Help>Configure the RGB Value when in Night Light Mode. Byte 1: Red Color Byte 2: Green Color Byte 3: Blue Color</Help>
				</Value>
				<Value type="int" genre="config" instance="1" index="84" label="RGB Brightness in Energy Mode" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="16777215" value="5263440">
					<Help>Configure the brightness level of RGB LED (0%-100%) when it is in Energy Mode/momentary indicate mode. Byte 1: Red Color Byte 2: Green Color Byte 3: Blue Color</Help>
				</Value>
				<Value type="bool" genre="config" instance="1" index="90" label="Enables/disables parameter 91/92" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="False">
					<Help>Enable/disable Wattage threshold and percent.</Help>
				</Value>
				<Value type="short" genre="config" instance="1" index="91" label="Minimum Change to send Report (Watt)" units="watts" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="32000" value="25">
					<Help>The value represents the minimum change in wattage for a Report to be sent (default 25 W)</Help>
				</Value>
				<Value type="byte" genre="config" instance="1" index="92" label="Minimum Change to send Report (%)" units="%" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="100" value="5">
					<Help>The value represents the minimum percentage change in wattage for a Report to be sent (Default 5)</Help>
				</Value>
				<Value type="button" genre="config" instance="1" index="100" label="Default Group Reports" units="" read_only="false" write_only="true" verify_changes="false" poll_intensity="0" min="0" max="0" affects="101,102,103">
					<Help>Set report types for groups 1, 2 and 3 to default.</Help>
				</Value>
				<Value type="int" genre="config" instance="1" index="101" label="Report type sent in Reporting Group 1" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="0">
					<Help>Defines the type of report sent for reporting group 1. 2 is multisensor report. 4 is meter report for watts. 8 is meter report for kilowatts. Value 1 (msb) Reserved Value 2 Reserved Value 3 Reserved Value 4 (lsb) bits 7-4 reserved bit 3 KWH bit 2 Watt bit 1 Current bit 0 Voltage</Help>
				</Value>
				<Value type="int" genre="config" instance="1" index="102" label="Report type sent in Reporting Group 2" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="0">
				</Value>
				<Value type="int" genre="config" instance="1" index="103" label="Report type sent in Reporting Group 3" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="0">
				</Value>
				<Value type="button" genre="config" instance="1" index="110" label="Set 111 to 113 to default" units="" read_only="false" write_only="true" verify_changes="false" poll_intensity="0" min="0" max="0" affects="111,112,113">
					<Help>Set time interval for sending reports for groups 1, 2 and 3 to default.</Help>
				</Value>
				<Value type="int" genre="config" instance="1" index="111" label="Send Interval for Reporting Group 1" units="seconds" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="-1" value="3">
					<Help>Defines the time interval when the defined report for group 1 is sent.</Help>
				</Value>
				<Value type="int" genre="config" instance="1" index="112" label="Send Interval for Reporting Group 2" units="seconds" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="-1" value="600">
					<Help>Defines the time interval when the defined report for group 2 is sent.</Help>
				</Value>
				<Value type="int" genre="config" instance="1" index="113" label="Send Interval for Reporting Group 3" units="seconds" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="-1" value="600">
					<Help>Defines the time interval when the defined report for group 3 is sent.</Help>
				</Value>
				<Value type="list" genre="config" instance="1" index="200" label="Partner ID" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="1" vindex="0" size="1">
					<Help>Partner ID</Help>
					<Item label="Aeon Labs Standard (Default)" value="0" />
					<Item label="Others" value="1" />
				</Value>
				<Value type="list" genre="config" instance="1" index="252" label="Configuration Locked" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="1" vindex="0" size="1">
					<Help>Enable/disable Configuration Locked</Help>
					<Item label="Disable" value="0" />
					<Item label="Enable" value="1" />
				</Value>
				<Value type="short" genre="config" instance="1" index="254" label="Device tag" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="65535" value="0">
					<Help>Device tag.</Help>
				</Value>
				<Value type="button" genre="config" instance="1" index="255" label="Reset device" units="" read_only="false" write_only="true" verify_changes="false" poll_intensity="0" min="0" max="0">
					<Help>Reset to the default configuration.</Help>
				</Value>
			</CommandClass>
			<CommandClass id="114" name="COMMAND_CLASS_MANUFACTURER_SPECIFIC" version="1" request_flags="4" innif="true">
			</CommandClass>
			<CommandClass id="115" name="COMMAND_CLASS_POWERLEVEL" version="1" request_flags="4" innif="true">
				<Value type="list" genre="system" instance="1" index="0" label="Powerlevel" units="dB" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="0" size="1">
					<Item label="Normal" value="0" />
					<Item label="-1dB" value="1" />
					<Item label="-2dB" value="2" />
					<Item label="-3dB" value="3" />
					<Item label="-4dB" value="4" />
					<Item label="-5dB" value="5" />
					<Item label="-6dB" value="6" />
					<Item label="-7dB" value="7" />
					<Item label="-8dB" value="8" />
					<Item label="-9dB" value="9" />
				</Value>
				<Value type="byte" genre="system" instance="1" index="1" label="Timeout" units="seconds" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0" />
				<Value type="button" genre="system" instance="1" index="2" label="Set Powerlevel" units="" read_only="false" write_only="true" verify_changes="false" poll_intensity="0" min="0" max="0" />
				<Value type="byte" genre="system" instance="1" index="3" label="Test Node" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0" />
				<Value type="list" genre="system" instance="1" index="4" label="Test Powerlevel" units="dB" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="0" size="1">
				</Value>
				<Value type="short" genre="system" instance="1" index="5" label="Frame Count" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="-32768" max="32767" value="0" />
				<Value type="button" genre="system" instance="1" index="6" label="Test" units="" read_only="false" write_only="true" verify_changes="false" poll_intensity="0" min="0" max="0" />
				<Value type="button" genre="system" instance="1" index="7" label="Report" units="" read_only="false" write_only="true" verify_changes="false" poll_intensity="0" min="0" max="0" />
				<Value type="list" genre="system" instance="1" index="8" label="Test Status" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="0" size="1">
					<Item label="Failed" value="0" />
					<Item label="Success" value="1" />
					<Item label="In Progress" value="2" />
				</Value>
				<Value type="short" genre="system" instance="1" index="9" label="Acked Frames" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-32768" max="32767" value="0" />
			</CommandClass>
			<CommandClass id="129" name="COMMAND_CLASS_CLOCK" version="1" request_flags="4" innif="true">
				<Value type="list" genre="user" instance="1" index="0" label="Day" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="0" size="1">
					<Item label="Monday" value="1" />
					<Item label="Tuesday" value="2" />
					<Item label="Wednesday" value="3" />
					<Item label="Thursday" value="4" />
					<Item label="Friday" value="5" />
					<Item label="Saturday" value="6" />
					<Item label="Sunday" value="7" />
				</Value>
				<Value type="byte" genre="user" instance="1" index="1" label="Hour" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="12" />
				<Value type="byte" genre="user" instance="1" index="2" label="Minute" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0" />
			</CommandClass>
			<CommandClass id="130" name="COMMAND_CLASS_HAIL" version="1" request_flags="4" after_mark="true" innif="true">
			</CommandClass>
			<CommandClass id="133" name="COMMAND_CLASS_ASSOCIATION" version="1" request_flags="4" innif="true">
				<Associations num_groups="2">
					<Group index="1" max_associations="5" label="LifeLine" auto="true" />
					<Group index="2" max_associations="5" label="Retransmit Switch CC" auto="false" />
				</Associations>
			</CommandClass>
			<CommandClass id="134" name="COMMAND_CLASS_VERSION" version="1" request_flags="6" innif="true">
				<Value type="string" genre="system" instance="1" index="0" label="Library Version" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="Unknown" />
				<Value type="string" genre="system" instance="1" index="1" label="Protocol Version" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="Unknown" />
				<Value type="string" genre="system" instance="1" index="2" label="Application Version" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="Unknown" />
			</CommandClass>
		</CommandClasses>
	</Node>
Here is the insecure switch
Insecure Switch
	<Node id="36" name="" location="" basic="4" generic="16" specific="1" roletype="5" devicetype="1792" nodetype="0" type="Binary Power Switch" listening="true" frequentListening="false" beaming="true" routing="true" max_baud_rate="40000" version="4" refreshonnodeinfoframe="false" query_stage="Complete">
		</Manufacturer>
		<CommandClasses>
			</CommandClass>
			</CommandClass>
				<Value type="byte" genre="user" instance="1" index="0" label="Level" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="99" />
				<Value type="byte" genre="system" instance="1" index="5" label="Dimming Duration" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="255" />
			</CommandClass>
				<Value type="list" genre="system" instance="1" index="0" label="Switch All" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="3" size="1">
				</Value>
			</CommandClass>
				<Value type="decimal" genre="user" instance="1" index="0" label="Energy" units="kWh" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="0.790" />
				<Value type="decimal" genre="user" instance="1" index="1" label="Previous Reading" units="kWh" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="0.790" />
				<Value type="int" genre="user" instance="1" index="2" label="Interval" units="seconds" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="65535" />
				<Value type="decimal" genre="user" instance="1" index="8" label="Power" units="W" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="0.000" />
				<Value type="decimal" genre="user" instance="1" index="16" label="Voltage" units="V" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="201.108" />
				<Value type="decimal" genre="user" instance="1" index="20" label="Current" units="A" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="0.000" />
				<Value type="bool" genre="user" instance="1" index="32" label="Exporting" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="False" />
				<Value type="button" genre="system" instance="1" index="33" label="Reset" units="" read_only="false" write_only="true" verify_changes="false" poll_intensity="0" min="0" max="0" />
			</CommandClass>
			<CommandClass id="51" name="COMMAND_CLASS_COLOR" version="1" request_flags="2" innif="true" colorchannels="28">
				<Value type="string" genre="user" instance="1" index="0" label="Color" units="#RRGGBB" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="#1B141B" />
				<Value type="list" genre="user" instance="1" index="1" label="Color Index" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="17" size="0">
					<Item label="Off" value="0" />
					<Item label="Cool White" value="1" />
					<Item label="Warm White" value="2" />
					<Item label="Red" value="3" />
					<Item label="Lime" value="4" />
					<Item label="Blue" value="5" />
					<Item label="Yellow" value="6" />
					<Item label="Cyan" value="7" />
					<Item label="Magenta" value="8" />
					<Item label="Silver" value="9" />
					<Item label="Gray" value="10" />
					<Item label="Maroon" value="11" />
					<Item label="Olive" value="12" />
					<Item label="Green" value="13" />
					<Item label="Purple" value="14" />
					<Item label="Teal" value="15" />
					<Item label="Navy" value="16" />
					<Item label="Custom" value="17" />
				</Value>
				<Value type="int" genre="system" instance="1" index="2" label="Color Channels" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="28" />
			</CommandClass>
			</CommandClass>
			</CommandClass>
				</Value>
				</Value>
				</Value>
				</Value>
				</Value>
				</Value>
				</Value>
				<Value type="byte" genre="config" instance="1" index="85" label="Parameter #85" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="5" />
				</Value>
				</Value>
				</Value>
				</Value>
				</Value>
				</Value>
				</Value>
				</Value>
				</Value>
				</Value>
				</Value>
				</Value>
				</Value>
				</Value>
				</Value>
			</CommandClass>
			</CommandClass>
				</Value>
				</Value>
				</Value>
			</CommandClass>
				<Value type="list" genre="user" instance="1" index="0" label="Day" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="6" size="1">
				</Value>
				<Value type="byte" genre="user" instance="1" index="1" label="Hour" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="2" />
				<Value type="byte" genre="user" instance="1" index="2" label="Minute" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="34" />
			</CommandClass>
			</CommandClass>
					<Group index="1" max_associations="5" label="LifeLine" auto="true">
						<Node id="1" />
					</Group>
				</Associations>
			</CommandClass>
			<CommandClass id="134" name="COMMAND_CLASS_VERSION" version="1" request_flags="4" innif="true">
				<Value type="string" genre="system" instance="1" index="0" label="Library Version" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="3" />
				<Value type="string" genre="system" instance="1" index="1" label="Protocol Version" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="4.05" />
				<Value type="string" genre="system" instance="1" index="2" label="Application Version" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="1.03" />
			</CommandClass>
		</CommandClasses>
	</Node>
There are some differences in the configuration but i’m just a beginner here so not sure what it could be
No any device that’s permanently powered (not battery powered) will help build the mesh
Thanks @Tinkerer
So just to confirm that I do not have to add my Aeon Smart Switches securely? Because as of right now, I cannot get them to work past joining the nextwork (no switch, capabilities, reporting)
If I may, Is there a way to know if my devices are properly working as repeaters? I have z-wave graph installed but it doesn’t look like anything is repeating…
No, you don’t. The only things that need it are things like locks
If they are mains/USB powered, they’re a repeater. As simple as that.
Sweet. Thanks much Tinkerer. I can revert back to the non-secure mode then given what I read about the key only viable for attack during handshake.
Side question, if I could… Is there a way to force a node to use a repeater rather than the potentially unstable connection to the hub? How do I know if my smart switch is acting like a repeater?
No, and not really.
With Z-Wave Plus (and later) the neighbour list is just a vague indicator of things. Z-Wave plus first tries direct, then via the neighbours, then via a broadcast.
As with Zigbee, just let the mesh protocol sort itself out.
Thanks @Tinkerer. I’ll give it a shot. I’ve got some problematic sensors (garage) that cannot go direct so I’m trying to put more repeater type devices in the ceiling to act as repeaters but struggle to confirm if they are working
Two things you can do.
One, is look at the diagram, it’ll give you a hint
The other is to check the various RTT attributes to see if they come down
It seems that when I break things, sometimes I fix things.
Last night I did a network heal, which then seem to rename all my sensors back to their original names (I have 8 x Ecolink sensors) with the same Node ID’s… So that’s a PITA, but…
It seems the graph works now and repeaters are working.
However, teh node ID’s are wrong
Eg, this Aeon Smart Switch (node ID is 36) but when I click on it it shows that it is Ecolink (battery) open/close sensor and the ID is wrong
