I have a problem with z-wave. My Radio Frequency Region settings change to ‘automatic’ every time i restart home assistant. i am from israel but i use modules from europe so i need the Redio Frequency to be ‘europe’.
Every restart make me go to the add-ons screen and change the radio frequency to ‘europe’.
I need help fixing it.
For whichever add-on you are using, go into its settings and change the frequency/region. Sounds like you are not changing the setting.
I did this. The problem is that it changes back to automatic on every restart …
Please provide more detail as to what you are doing. We don’t even know which add-on you are using. What setting are you changing?
For Z-Wave JS core add-on, set the rf_region setting in the add-on settings: addons/zwave_js/DOCS.md at f68e2824a0a3c9c4524cf3cc7547397d496c48c8 · home-assistant/addons · GitHub
For Z-Wave JS UI community add-on, set the Default Radio configuration: RF Region setting from the Web UI in Settings → Z-Wave.
Be sure to select the Save buttons in each to persist the setting.
i am using z-wave js addon (not the ui).
Each time i restart home assistant, the radio frequncy changes to automatic and than i need to go and change it back to europe and save. It lasts until i restart my home assistant.
