Hello all!
Home Assistant looks to be one of the top choices for a DIY home automation system. I just started messing around with a few things. I installed a new light fixture with dimmable lights, and got a GE Z-Wave Smart Dimmer. I then got the Aeon Labs Aeotec Z-Wave Z-Stick, Gen5.
I have a server on 24/7 running unRAID. I installed Home-Assistant using docker. While a pain in the backside to try and get the docker to recognize the USB stick, I finally prevailed! But then my issue was, it seemed like my connectivity was basically non-existent. It knew the Z-Wave stick was paired to the dimmer, but had no one to control it.
I decided to carry my server upstairs and give it a try. The server typically sits one floor below, but almost directly below the z-wave dimmer. Without any roofing obstructions, and about 20 feet across the room, it improved, but was still quite flaky.
Does anyone have any experience with Z-Wave and Home-Assistant that could possibly steer me in the right direction?
As an aside, I did test out the stick with HomeGenie. IMO, an inferior interface, but for some reason, was able to connect to the dimmer flawlessly.
