Z-Wave Raspberry Pi 2 with Ezzee
I have a Raspberry Pi 2 with an Ezzee board, which is similar to the Razberry but without custom software.
I have disabled the Raspberry Pi serial console in /boot/cmdline.txt, and made sure that Home Assistant has access to the serial port (/dev/ttyAMA0).
Here is what I have in configuration.yaml
zwave:
   config_path: /srv/homeassistant/src/python-openzwave/openzwave/config
   usb_path: /dev/ttyAMA0
And here is the output of Home Assistant, no matter what I try
WARNING:homeassistant.setup:Setup of sensor is taking over 10 seconds.
Am I doing something wrong, or is there some concept i’m missing?
That output in the log is nothing to do with the Zwave component, and is not actually a problem, just information.
What’s wrong with the Zwave on your system?
