When I press refresh button I see in zwave log that there is called some API function: 2022-11-14 18:19:00.304 INFO Z-WAVE: Calling api refreshCCValues with args: [ 86, 112, [length]: 2 ]
So my question can I call this refresh function and if is how I can do this?
Is maybe possible call refresh only one parameter inside this configuration? I need manually periodic refresh this value because Thermostatic Head sometime forget change it and when I refresh it manually it change state…
Versions:
Home Assistant 2022.11.2
Supervisor 2022.10.2
Operating System 9.3
Frontend: 20221108.0 - latest
zwave-js-ui: 8.4.1
zwave-js: 10.3.0
{Edit} Apologies, I hadn’t noticed that it was the configuration that you were trying to refresh. This won’t work, you could try posting in the zwave-js github issues also.
Thanks for reply and help. @freshcoast hint help me solve problem. Im try his code and run automation but it give me error: Endpoint(node_id=86, index=1) - NotFoundError: Command class 112 not found on endpoint Endpoint(node_id=86, index=1)
Then Im try set endpoint to 0 and it start working, so automation now looks like:
Configuration CC is only valid for the root device (endpoint 0). There was no reason to set it, which is why I never included it in the sample code. You can remove endpoint entirely.
No, you’re correct. There’s a distinction between inferred endpoints when specifying entity_id vs. device or area:
For entity_id:
If endpoint is specified, that endpoint will be used to make the CC API call for all devices, otherwise the primary value endpoint will be used for each entity.
For device_id/area:
If endpoint is specified, that endpoint will be used to make the CC API call for all devices, otherwise the root endpoint (0) will be used for each device.
If you use device_id instead (which I usually use in these examples), it will choose endpoint 0 automatically. If using entity, you should specify endpoint. It could be smarter, I suppose, depending on the CC being using, but it’s working as intended.
