Simple question…
Why don’t entity IDs for things like ZWave remotes appear in the front end ?
We still have to press a button & check log files to work out what they are?
Cheers!
Simple question…
Cheers!
Have you looked in the states menu, which is under Developer tools on the left, and looks like <>
. That’s where you can find all entities.
Ah ok I’ll take a look.
So any reason they are not displayed in the main view ?
If by main view you mean the old default view, they’re not shown there by default.
Ok. I’ll have another look tonight.
Btw I’m reinstalling HA - it’s been about 12 months since I last updated the PI setup (raspbian + ha) so going for a full reinstall using a pi b3+
Lots and lots of changes for you then
There will be a lot of breaking changes that may cause issues. Have a read of this summary before copying your config over.
Yep I’m aware. I’m not copying anything over - it’s a complete rebuild from scratch.
All sorted now! Not only did I manage to find them I also renaming them to my own standard and setup automations etc.
Only question now is…
If I have clicked on the cog and put my own values in “name” and “entity ID” but the question is, where is this stored ? customize.yaml is empty.
core.entity_registry in \config\.storage
Not meant to be user editable.
ok thanks!
could you elaborate more on your naming standards?
I now see there would be a huge benefit of putting in both function and area in the entity name itself; sensor.motion_garage.
Appreciate all ideas
