Z-wave scene activation help
I have a Fibaro dimmer 2 and a Telldus TZWP-100 plug switch. The Dimmer has two inputs, S1 and S2. S1 controlls the light directly connected to the load, and I want S2 to control the Telldus switch (on/off). I am having a hell of time getting this to work. I just migrated from Domoticz where I got this to work - Home Assistant is different.
I have this in the automations.yaml:
- id: '1553445392815'
  alias: lights
  - event_data:
      entity_id: light.fibaro_system_fgd212_dimmer_2_level
      scene_id: 24
    event_type: zwave.scene_activated
    platform: event
  - data:
      entity_id: switch.telldus_tzwp_100_plug_in_switch_switch
    service: switch.turn_off
Nothing happens when I double-click the momentary switch, which is scene_id: 24.
I get this in the OZW log:
2019-04-05 20:07:20.619 Detail, Node002,   Received: 0x01, 0x0a, 0x00, 0x04, 0x00, 0x02, 0x04, 0x2b, 0x01, 0x18, 0x00, 0xc5
2019-04-05 20:07:20.622 Detail,
2019-04-05 20:07:20.624 Info, Node002, Received Scene Activation set from node 2: scene id=24 now. Sending event notification.
2019-04-05 20:07:20.638 Detail, Node002, Notification: SceneEvent
So it seems it is picking something up, but the automation isn’t triggering. I can trigger it manually from the HA ui, but not from the switch. I feel like I’ve been tinkering with this for a long while now with no progress.
I’ve seen scene_data being used some places, but not sure if that’s what I’m missing?
Any help would be greatly appreciated.
Wrong entity id for the event data. Zwave scene events use the zwave entity.
Thank you for the reply!
I changed it to this:
  alias: lights
  - event_data:
      entity_id: zwave.fibaro_system_fgd212_dimmer_2
      scene_id: 24
    platform: event
  - data:
It didn’t work.
Do I need to configure anything in the Z-Wave Node Management section of the UI? Group associations?
Looking at the following, I would suggest associating group 5 to “control” your z-wave stick. There have been a couple topics about GE/JASCO switches via group 3 associations.
https://products.z-wavealliance.org/products/1736/assoc?noFilename=True
