I have HA installed on a pi3 with the all in one installer. I had a few days of learning curves because I couldn’t see the two GE 12722 switches at first, then I could but not control them. A lot of searching on the forums and internet pointed me to a solution. I had it finally up and running and even had ha-bridge going and Echo controlling my harmony hub and those switches. So I updated to .21 through the directions in the tutorials here and now I am back in the same boat. I know my problem is like the ones staring me in the face in blue to the right of me typing right now. I felt this was different enough then those issues because it seems mine was finally working from solutions in those threads but now it isn’t after the update. Let me know what else you need. The log only says the below:
16-06-11 22:44:58 homeassistant.components.zwave: zwave not ready after 30 seconds, continuing anyway
Config is:
homeassistant:
# Name of the location where Home Assistant is running
# C for Celsius, F for Fahrenheit
temperature_unit: F
# Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones
time_zone: US/Eastern
latitude: XXXXXX
longitude: XXXXX
customize:
switch.ge_12722_onoff_relay_switch_switch_4:
friendly_name: Table Light
switch.__switch_2:
friendly_name: Kitchen Light
zwave:
usb_path: /dev/ttyACM0
config_path: /srv/hass/src/python-openzwave/openzwave/config
polling_interval: 10000
customize:
polling_intensity: 1
switch.__switch_2:
I know there were some issues with polling and it seems they are back or the solutions to those issues don’t solve the communication anymore. Any ideas why I can see them in HA but not able to control them anymore?
