I am setting up my first Z-Wave network and trying it out with just the controller and one z-wave switch. It’s an Eaton accessory switch. It shows up just fine as RF9517 Accessory Light Switch and there is a Remote Switch Switch entity. But when I try to toggle it, the command fails.
I’m using Home Assistant 0.118.5 on a Raspberry Pi 3 B and a Zooz Z-Wave Plus S2 USB Stick ZST10.
2020-12-10 21:24:12.484 Detail, Node005, Removing current message
2020-12-10 21:24:12.484 Detail, Node005, Notification: Notification - TimeOut
2020-12-10 21:24:14.406 Detail, Node001, Queuing (Controller) Request Node Neighbor Update
2020-12-10 21:24:14.406 Detail, Node005, Queuing (Controller) Request Node Neighbor Update
2020-12-10 21:24:14.407 Info, Requesting Neighbor Update for node 1
2020-12-10 21:24:14.407 Detail, Node001, Queuing (Command) ControllerCommand_RequestNodeNeighborUpdate (Node=1): 0x01, 0x05, 0x00, 0x48, 0x01, 0x20, 0x93
2020-12-10 21:24:14.407 Detail, Notification: ControllerCommand - Starting
2020-12-10 21:24:14.408 Detail,
2020-12-10 21:24:14.408 Info, Node001, Sending (Command) message (Callback ID=0x20, Expected Reply=0x48) - ControllerCommand_RequestNodeNeighborUpdate (Node=1): 0x01, 0x05, 0x00, 0x48, 0x01, 0x20, 0x93
2020-12-10 21:24:14.554 Detail, Node001, Received: 0x01, 0x05, 0x00, 0x48, 0x20, 0x21, 0xb3
2020-12-10 21:24:14.554 Info, Node001, REQUEST_NEIGHBOR_UPDATE_STARTED
2020-12-10 21:24:14.554 Detail, Node033, Expected callbackId was received
2020-12-10 21:24:14.554 Detail, Node033, Expected reply was received
2020-12-10 21:24:14.554 Detail, Node033, Message transaction complete
2020-12-10 21:24:14.554 Detail, Node001, Removing current message
2020-12-10 21:24:14.554 Detail, Notification: ControllerCommand - InProgress
2020-12-10 21:24:14.555 Info, WriteNextMsg Controller nothing to do
2020-12-10 21:24:24.210 Detail, Received: 0x01, 0x05, 0x00, 0x48, 0x20, 0x23, 0xb1
2020-12-10 21:24:24.210 Warning, WARNING: REQUEST_NEIGHBOR_UPDATE_FAILED
2020-12-10 21:24:24.210 Detail, Notification: ControllerCommand - Failed
2020-12-10 21:24:24.211 Info, Requesting Neighbor Update for node 5
2020-12-10 21:24:24.211 Detail, Node005, Queuing (Command) ControllerCommand_RequestNodeNeighborUpdate (Node=5): 0x01, 0x05, 0x00, 0x48, 0x05, 0x21, 0x96
2020-12-10 21:24:24.212 Detail, Notification: ControllerCommand - Starting
2020-12-10 21:24:24.212 Info, Node005, Sending (Command) message (Callback ID=0x21, Expected Reply=0x48) - ControllerCommand_RequestNodeNeighborUpdate (Node=5): 0x01, 0x05, 0x00, 0x48, 0x05, 0x21, 0x96
2020-12-10 21:24:24.234 Detail, Node005, Received: 0x01, 0x05, 0x00, 0x48, 0x21, 0x21, 0xb2
2020-12-10 21:24:24.234 Info, Node005, REQUEST_NEIGHBOR_UPDATE_STARTED
2020-12-10 21:24:24.234 Detail, Node033, Expected callbackId was received
2020-12-10 21:24:24.234 Detail, Node033, Expected reply was received
2020-12-10 21:24:24.234 Detail, Node033, Message transaction complete
2020-12-10 21:24:24.234 Detail, Node005, Removing current message
2020-12-10 21:24:24.234 Detail, Notification: ControllerCommand - InProgress
2020-12-10 21:24:24.236 Info, WriteNextMsg Controller nothing to do
2020-12-10 21:24:24.579 Detail, Received: 0x01, 0x05, 0x00, 0x48, 0x21, 0x22, 0xb1
2020-12-10 21:24:24.580 Detail,
2020-12-10 21:24:24.580 Info, REQUEST_NEIGHBOR_UPDATE_DONE
2020-12-10 21:24:24.580 Detail, Requesting routing info (neighbor list) for Node 5
2020-12-10 21:24:24.580 Detail, Node005, Queuing (Command) Get Routing Info (Node=5): 0x01, 0x07, 0x00, 0x80, 0x05, 0x00, 0x00, 0x03, 0x7e
2020-12-10 21:24:24.580 Detail, Notification: ControllerCommand - Completed
2020-12-10 21:24:24.581 Detail,
2020-12-10 21:24:24.581 Info, Node005, Sending (Command) message (Callback ID=0x00, Expected Reply=0x80) - Get Routing Info (Node=5): 0x01, 0x07, 0x00, 0x80, 0x05, 0x00, 0x00, 0x03, 0x7e
2020-12-10 21:24:24.586 Detail, Node005, Received: 0x01, 0x20, 0x01, 0x80, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x5f
2020-12-10 21:24:24.586 Info, Node005, Received reply to FUNC_ID_ZW_GET_ROUTING_INFO
2020-12-10 21:24:24.586 Info, Node005, Neighbors of this node are:
2020-12-10 21:24:24.586 Info, Node005, Node 1
2020-12-10 21:24:24.586 Detail, Expected reply was received
2020-12-10 21:24:24.586 Detail, Message transaction complete
2020-12-10 21:24:24.586 Detail, Node005, Removing current message
2020-12-10 21:24:37.926 Info, Node005, Value::Set - COMMAND_CLASS_SWITCH_BINARY - Switch - 0 - 1 - True
2020-12-10 21:24:37.927 Info, Node005, SwitchBinary::Set - Setting node 5 to On
2020-12-10 21:24:37.927 Detail, Node005, Queuing (Send) SwitchBinaryCmd_Set (Node=5): 0x01, 0x0a, 0x00, 0x13, 0x05, 0x03, 0x25, 0x01, 0xff, 0x25, 0x22, 0x3c
2020-12-10 21:24:37.927 Detail, Node005, Queuing (Send) SwitchBinaryCmd_Get (Node=5): 0x01, 0x09, 0x00, 0x13, 0x05, 0x02, 0x25, 0x02, 0x25, 0x23, 0xc3
2020-12-10 21:24:37.927 Info, Node005, Sending (Send) message (Callback ID=0x22, Expected Reply=0x13) - SwitchBinaryCmd_Set (Node=5): 0x01, 0x0a, 0x00, 0x13, 0x05, 0x03, 0x25, 0x01, 0xff, 0x25, 0x22, 0x3c
2020-12-10 21:24:37.936 Detail, Node005, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2020-12-10 21:24:37.936 Detail, Node005, ZW_SEND_DATA delivered to Z-Wave stack
2020-12-10 21:24:37.957 Detail, Node005, Received: 0x01, 0x18, 0x00, 0x13, 0x22, 0x00, 0x00, 0x03, 0x00, 0xb8, 0x7f, 0x7f, 0x7f, 0x7f, 0x01, 0x01, 0x04, 0x00, 0x00, 0x00, 0x00, 0x02, 0x01, 0x00, 0x00, 0x6a
2020-12-10 21:24:37.957 Detail, Node005, ZW_SEND_DATA Request with callback ID 0x22 received (expected 0x22)
2020-12-10 21:24:37.957 Info, Node005, Request RTT 29 Average Request RTT 28
2020-12-10 21:24:37.957 Detail, Expected callbackId was received
2020-12-10 21:24:37.957 Detail, Expected reply was received
2020-12-10 21:24:37.957 Detail, Message transaction complete
2020-12-10 21:24:37.957 Detail, Node005, Removing current message
2020-12-10 21:24:37.958 Info, Node005, Sending (Send) message (Callback ID=0x23, Expected Reply=0x04) - SwitchBinaryCmd_Get (Node=5): 0x01, 0x09, 0x00, 0x13, 0x05, 0x02, 0x25, 0x02, 0x25, 0x23, 0xc3
2020-12-10 21:24:37.966 Detail, Node005, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2020-12-10 21:24:37.966 Detail, Node005, ZW_SEND_DATA delivered to Z-Wave stack
2020-12-10 21:24:37.986 Detail, Node005, Received: 0x01, 0x18, 0x00, 0x13, 0x23, 0x00, 0x00, 0x03, 0x00, 0xb8, 0x7f, 0x7f, 0x7f, 0x7f, 0x01, 0x01, 0x03, 0x00, 0x00, 0x00, 0x00, 0x02, 0x01, 0x00, 0x00, 0x6c
2020-12-10 21:24:37.986 Detail, Node005, ZW_SEND_DATA Request with callback ID 0x23 received (expected 0x23)
2020-12-10 21:24:37.986 Info, Node005, Request RTT 28 Average Request RTT 28
2020-12-10 21:24:37.986 Detail, Expected callbackId was received
2020-12-10 21:24:42.493 Detail, Node005, Polling: COMMAND_CLASS_SWITCH_BINARY index = 0 instance = 1 (poll queue has 0 messages)
2020-12-10 21:24:42.493 Detail, Node005, Queuing (Poll) SwitchBinaryCmd_Get (Node=5): 0x01, 0x09, 0x00, 0x13, 0x05, 0x02, 0x25, 0x02, 0x25, 0x24, 0xc4
2020-12-10 21:24:47.958 Error, Node005, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-12-10 21:24:47.959 Detail, Node005, Removing current message
2020-12-10 21:24:47.959 Detail, Node005, Notification: Notification - TimeOut
2020-12-10 21:24:47.962 Detail,
2020-12-10 21:24:47.963 Info, Node005, Sending (Poll) message (Callback ID=0x24, Expected Reply=0x04) - SwitchBinaryCmd_Get (Node=5): 0x01, 0x09, 0x00, 0x13, 0x05, 0x02, 0x25, 0x02, 0x25, 0x24, 0xc4
2020-12-10 21:24:47.971 Detail, Node005, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2020-12-10 21:24:47.972 Detail, Node005, ZW_SEND_DATA delivered to Z-Wave stack
2020-12-10 21:24:47.991 Detail, Node005, Received: 0x01, 0x18, 0x00, 0x13, 0x24, 0x00, 0x00, 0x02, 0x00, 0xb6, 0x7f, 0x7f, 0x7f, 0x7f, 0x01, 0x01, 0x03, 0x00, 0x00, 0x00, 0x00, 0x02, 0x01, 0x00, 0x00, 0x64
2020-12-10 21:24:47.991 Detail, Node005, ZW_SEND_DATA Request with callback ID 0x24 received (expected 0x24)
2020-12-10 21:24:47.991 Info, Node005, Request RTT 28 Average Request RTT 28
2020-12-10 21:24:47.991 Detail, Expected callbackId was received
2020-12-10 21:24:57.963 Error, Node005, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-12-10 21:24:57.963 Detail, Node005, Removing current message
2020-12-10 21:24:57.963 Detail, Node005, Notification: Notification - TimeOut
